Connection Aborted - Download and Upload
2 replies to this topic
#1 rbaillargeon
rbaillargeon
  • 3 posts
Posted 13 February 2003 - 01:53 PM
<was this post moved to the "Users Helping Users" Forum? Why?>
This occurs when using the session queue. I have read the other posts pertaining to this problem, but none of the solutions are working for me.
The Problem
If I set up a Session Queue and execute "transfer" everything is fine until the currently transfering file is completed. The file is transffered completely (every byte), but before it is removed from the Session Queue I get this message immediately:
An established connection was aborted by the software in your host machine. Connection closed.
There is no pause between the file completing and the disconnect. This seems to rule out a server timeout. I have replicated this error with a 120s server timeout. I have my resume settings set to "resume" by default on file exist. Once I press "transfer" again the file is compared and then skipped.
The problem occurs with every item in my queue that is "large". I am transferring mostly 60MB files, smaller text files seem to transfer fine. Although this is not always the case. In other words:
Large Files: 100% repeatable
Small Files: not consistently repeatable
Your help would be greatly appreciated. I have been using SmartFTP for a long time now, well over a year. This problem has only started since about December after a regular update. Although I cant remember which version. If there is an older build I would like to try it and see if it has the same error.
This stuff Might Help....
200 Port command successful.
    Opening data connection IP: 192.168.0.37 PORT: 3849.
    STOR Lucien Foort 07-23-2002 Nightlife clubmix Part 1.mp3
150 Opening data connection for Lucien Foort 07-23-2002 Nightlife clubmix Part 1.mp3.
    84805509 bytes sent successfully. (50.01 KB/s) (00:27:36).
    Connection closed.
Service Pack 3 (Build 2195)
CPU Speed         : 797 MHz
Total Memory      : 523820 KB
Free Memory       : 214128 KB
Version           : 1.0.974.0
Time Stamp        : 2003-02-09 16:16:05
Controls.dll      : 1.6.974.0
FTPAPI.dll        : 2.0.974.0
Language.dll      : 1.0.974.0
ResEng.dll        : 1.3.974.0
shell32.dll       : 5.00.3502.6144
shlwapi.dll       : 6.00.2800.1106
comctl32.dll      : 5.81
riched20.dll      : 5.30.23.1209
schannel.dll      : 5.00.2195.5284
Version           : 6.0.2800.1106
Winsock           : 2.2
As a workaround, is there an option to reconnect to the server if disconnected and continnue to transfer a Session Queue?
Also, is the only way to Queue uploads through the Session Queue?
Is this planned to change? Uploads through Global Queue?
Posted 13 February 2003 - 04:35 PM
Do you make localhost->localhost transfers?
If this is not the case the control connection (where the commands and replies are sent) does very likely timeout during long transfers and the control connection gets closed by your NAT router.
You can easily solve the problem by using the global queue.
http://www.smartftp.com/support/howto
Global Queue - Upload Tutorial
#3 rbaillargeon
rbaillargeon
  • 3 posts
Posted 14 February 2003 - 02:32 AM
thank you...
i can now continue to use your product with joy and enthusiasm.
