How to disable SSL?
9 replies to this topic
#1 MagamiEiko
MagamiEiko
  • 15 posts
Posted 28 October 2002 - 01:58 AM
I care absolutely nothing for the SSL abilities of smartftp. It's slow, a pain in the ass, and I just generally do not like it being enabled. How do I turn it off?
I try setting Connection mode to "Clear Data Connection" but it keeps getting reset almost everytime I start smartftp.
#2 MagamiEiko
MagamiEiko
  • 15 posts
Posted 28 October 2002 - 04:13 AM
I am uploading to another PC within the lan, and the upload using FlashFXP is ~3Mbytes/sec, and pretty constant(between 2.5 and 3.2), whereas SmartFTP is around 800K-1200K/sec.
I set the buffer size to 8192K, and I had read in another forum that SSL was the cause of this. I am using the latest dev build.
Upping the cache amount to 32000 K made it start out faster, but steadily drops to around 1MB/sec.
Oh, and while I'm at it, downloading from the LAN through smartftp is on par with the 'other' client.
While i'm at it, here's some useful information:
Service Pack 1 (Build 2600)
CPU Speed : 664 MHz
Total Memory : 392496 KB
Free Memory : 212992 KB
Version : 1.0.970.0
Controls.dll : 1.6.970.0
Controls2.dll : 1.6.970.0
FTPAPI.dll : 2.0.970.0
Language.dll : 1.0.970.0
ResEng.dll : 1.3.970.0
shell32.dll : 6.00.2800.1106 (xpsp1.020828-1920)
shlwapi.dll : 6.00.2800.1106 (xpsp1.020828-1920)
riched20.dll : 5.30.23.1211
msvcrt.dll : 7.0.2600.1106 (xpsp1.020828-1920)
msvcp60.dll : 6.00.8972.0
Version : 6.0.2800.1106
#3 mb
  • 11935 posts
Posted 28 October 2002 - 12:52 PM
Set the IO buffer size to 256KB or 512KB. And make sure you have SSL disabled if you don't want to use it.
#4 MagamiEiko
MagamiEiko
  • 15 posts
Posted 28 October 2002 - 02:41 PM
Setting it to 512 has limited my upload speed to 500-600K/sec. This is going through the *lan*, not the internet. It's acceptable on the net of course since I won't ever see that high.
#5 MagamiEiko
MagamiEiko
  • 15 posts
Posted 28 October 2002 - 06:32 PM
*Watches as MS reads this forum and comes breaking down my door*
Okay, the FTPD that is being used is something that is included in the Evolution X software for the XBOX. To use it, you have to mod your xbox and then load the software.
Many people are having a very similar problem, FlashFXP seems to work quite well, though.
Some have fixed it with setting their I/O buffer *really* high, but it just does not seem to fix it for me. I assumed since FlashFXP works well, that it's something to do with SmartFTP.
Unfortunately I know you guys probably don't have the means to tesst this, but be sure I am contacting both sides of developers(Both the devs of Evolution X and you guys), since I enjoy both pieces of software.....and I just dont feel like paying $25 for FlashFXP, 'cause SmartFTP has been great up until now.
  • 11935 posts
Posted 28 October 2002 - 07:36 PM
We have several testers using SmartFTP to upload their "stuff" to the XBOX and they all reported its faster than with flashfxp once they increased the IO buffer.
#7 TheGipper
TheGipper
Posted 11 March 2003 - 04:26 PM
my problem was a limit on the upload speeds to my xbox. I downgraded to build 970 from a chinese website and it fixed my xbox upload problems immediately. I love SmartFTP and it's fast, but something changed after 970 that broke xbox upload speeds for me.
  • 11935 posts
Posted 11 March 2003 - 05:22 PM
We're working on it.
I've sent you a private build to test the XBOX uploads.
#9 Aokromes
Aokromes
    Entity From Outer Space
  • 1519 posts
Posted 12 March 2003 - 04:12 AM
Using FlashFXP 2.0 (build 906)
Connecting to - XOOX -
Connected to 192.168.0.2 Port 21
220 Please enter your login name now.
USER xbox
331 Password required for xbox.
PASS (hidden)
230 User xbox logged in , proceed.
SYST
215 UNIX Type: L8
REST 100
502 rest is not implemented.
This site may not allow file resuming
CWD /E/
250 "/E/" is current directory.
PWD
257 "/E/" is current directory
TYPE A
200 Type set to ASCII.
PORT 192,168,0,1,13,118
200 Port command ok.
LIST
150 Opening ASCII data connection for ls /E/.
226 Transfer finished successfully. Data connection closed.
TYPE I
200 Type set to IMAGE.
PORT 192,168,0,1,13,119
STOR dnl-lott.part001.rar
150 Opening BINARY data connection for E:dnl-lott.part001.rar
Transferred: dnl-lott.part001.rar 47,68 MB in 8,48 (5.754,64 KBps)
Transfer queue completed
Transferred 1 file totaling 47,68 MB in 8,59 (5.754,64 KBps)
TYPE A
PORT 192,168,0,1,13,120
LIST
TYPE I
PORT 192,168,0,1,13,121
RETR dnl-lott.part001.rar
150 Sending E:dnl-lott.part001.rar
Transferred: dnl-lott.part001.rar 47,68 MB in 31,48 (1.550,89 KBps)
Transferred 1 file totaling 47,68 MB in 31,56 (1.550,89 KBps)
Using Smartftp Version : 1.0.974.9 Time Stamp : 2003-03-04 04:23:55, 1 KB IO buffer size
Resolving host name 192.168.0.2...
Connecting to (192.168.0.2).
Connected to (192.168.0.2) -> IP: 192.168.0.2 PORT: 21.
USER xbox
PASS (hidden)
SYST
215 UNIX Type: L8
FEAT
502 feat is not implemented.
REST 100
TYPE I
REST 100
PWD
257 "/" is current directory
Cached directory reloaded.
CWD /E
PWD
PORT 192,168,0,1,13,129
Opening data connection IP: 192.168.0.1 PORT: 3457.
50000000 bytes sent successfully. (6103.52 KB/s) (00:00:08).
TYPE A
PORT 192,168,0,1,13,130
Opening data connection IP: 192.168.0.1 PORT: 3458.
LIST -aL
818 bytes received successfully. (818 B/s) (00:00:01).
TYPE I
PORT 192,168,0,1,13,132
Opening data connection IP: 192.168.0.1 PORT: 3460.
50000000 bytes received successfully. (1953.13 KB/s) (00:00:25).
#10 mb
  • 11935 posts
Posted 12 March 2003 - 11:40 PM
Workaround is in next developer build.
Stay tuned.
