Bugs in 6.0.2016
Best Answer mb , 21 May 2014 - 10:04 AM
>1
The behavior is now consistent with the one from the Windows File Explorer.
>6
F5 is a key shortcut for Refresh and not for Reload. Use Reload from the context menu.
-> The Refresh command behaves now as before
>7
text file: We don't see the problem here. The list of files you can create is provided to us by the shell (operating system).
Dropfolder: Fixed. Go to the full post
11 replies to this topic
#1 Stanislav
Stanislav
  • 40 posts
Posted 13 May 2014 - 03:34 PM
version 6.0.2016
1. Previous location is empty even visit several locations
http://screencast.com/t/rInejGVHLc
2. Active files still doesn't highlight
http://screencast.com/t/qYuxV46B
3. Backspace button doesn't work =((((((
4. Promts doesn't work
Even I choise http://screencast.com/t/fAXR65QJZJ
The program still asks me about deleting the file
5. When I browse through the central panel, the navigation pane does not displays the folder tree. For example, I browse to the folder /modules/mod_related_items/tmpl (see screen)
and in the navigation pane displays the still /modules/, although the tree should expand, as it was in previous versions of SmartFTP.
  • 11975 posts
Posted 13 May 2014 - 05:05 PM
Please install the latest version:
>1
Did you manually enter the path/address into the address input box?
>2
You may have noticed that the Windows File Explorer uses only one drop down button for the history. In SmartFTP there are dedicated buttons for back/forward. But we have now added the current location to the back/forward dropdown menu.
>3
Confirmed and fixed.
>4
This setting has now been removed from the prompts. SmartFTP uses the default Windows setting. You can change it in the properties of Recycle Bin in Windows.
>5
The link is broken. But maybe you didn't enable the [x] Expand to current folder in the navigation pane control? Right-click on an empty space, then enable the expand option.
#3 Stanislav
Stanislav
  • 40 posts
Posted 14 May 2014 - 06:46 AM
1. I just walk on ftp. In previous versions I saw here history of visited paths
2. I mean if I stay in some tab, lets it highlight in Active files, like http://screencast.com/t/KNvJePD9N
3. Thanks
4. Ok
5. It's ok, thanks
Edited by Stanislav, 14 May 2014 - 06:46 AM.
#4 Stanislav
Stanislav
  • 40 posts
Posted 16 May 2014 - 10:09 AM
version 6.0.2017
6. Reload doesn't work
When I'm in a directory and click update, the list of files is not updated remain the same files. Until then, while not go to another folder and then return back.
Edited by Stanislav, 16 May 2014 - 10:09 AM.
#5 mb
  • 11975 posts
Posted 16 May 2014 - 11:51 AM
>6
What exactly has changed? New files? Size? Date? etc?
#6 Stanislav
Stanislav
  • 40 posts
Posted 16 May 2014 - 07:35 PM
>6
new files
Edited by Stanislav, 16 May 2014 - 07:36 PM.
#7 mb
  • 11975 posts
Posted 16 May 2014 - 08:02 PM
>6
We are not able to reproduce this problem.
  • 11975 posts
Posted 18 May 2014 - 04:58 PM
>2
We have changed it. The new build is available now.
>6
Any chance you can provide more details (or file a proper bug report)?
#9 Stanislav
Stanislav
  • 40 posts
Posted 21 May 2014 - 06:28 AM
Version 6.0.2020
1. Does anyone have any idea why stopped working?
2. Thanks
6. So, when I'm in a folder on FTP and I know that there dropped a file, I updated to F5, but do not see any change, ie prosihodit not even reboot the folder contents as previously.
And new bugs
7. When I choise Create (Создать in Russian) I don't see just a file and a I don't see txt file http://screencast.com/t/CQAV2QoAwxIx
And When I choise Create Dropbox folder the programm is shutting down
Edited by Stanislav, 21 May 2014 - 06:28 AM.
#10 mb
  • 11975 posts
Posted 21 May 2014 - 10:04 AM   Best Answer
>1
>6
>7
Dropfolder: Fixed.
#11 Stanislav
Stanislav
  • 40 posts
Posted 21 May 2014 - 08:10 PM
1. Look here http://screencast.com/t/m3kz3Lt3M
There is like history, right?
Why not do it in the drop-down list with full path, as was early, for example http://screencast.com/t/nMYYgf2ubfU
6. Used as Refresh and reload
7. Ok, but where is txt file... (
#12 verdain
verdain
Posted 09 June 2014 - 08:59 AM
Hi, I miss the history too. It would be great to see it in the drop-down like in earlier versions.
