Finished of transfer of file
No replies to this topic
#1 macneb
macneb
  • 9 posts
Posted 21 December 2013 - 02:36 AM
I have a file that finished but then it started over from what i can see. here is the log file.
[20:56:04] Operation Begin
[20:56:04] Resolving host name "ols18.com"
[20:56:04] Connecting to 64.64.131.118 Port: 21
[20:56:04] Connected to ols18.com.
[20:56:04] 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
[20:56:04] 220-You are user number 55 of 550 allowed.
[20:56:04] 220-Local time is now 20:56. Server port: 21.
[20:56:04] 220-This server supports FXP transfers
[20:56:04] 220-IPv6 connections are also welcome on this server.
[20:56:04] 220 You will be disconnected after 15 minutes of inactivity.
[20:56:04] AUTH TLS
[20:56:04] 234 AUTH TLS OK.
[20:56:04] TLS 1.2 encrypted session established.
[20:56:04] Key Exchange: 4096 bit RSA
[20:56:04] Session Cipher: 128 bit AES
[20:56:04] Command channel protection set to Private.
[20:56:04] PBSZ 0
[20:56:04] 200 PBSZ=0
[20:56:04] USER markacampany
[20:56:04] 331 User markacampany OK. Password required
[20:56:04] PASS (hidden)
[20:56:04] 230 OK. Current directory is /
[20:56:04] SYST
[20:56:04] 215 UNIX Type: L8
[20:56:04] Detected Server Type: UNIX
[20:56:04] RTT: 33.490 ms
[20:56:04] FEAT
[20:56:04] 211-Extensions supported:
[20:56:04]  EPRT
[20:56:04]  IDLE
[20:56:04]  MDTM
[20:56:04]  SIZE
[20:56:04]  MFMT
[20:56:04]  REST STREAM
[20:56:04]  MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[20:56:04]  MLSD
[20:56:04]  AUTH TLS
[20:56:04]  PBSZ
[20:56:04]  PROT
[20:56:04]  ESTA
[20:56:04]  PASV
[20:56:04]  EPSV
[20:56:04]  SPSV
[20:56:04]  ESTP
[20:56:04] 211 End.
[20:56:04] PWD
[20:56:04] 257 "/" is your current location
[20:56:04] Getting properties (Date modified, Size) of "G:\MOVIES\Movies (original)\Universal Soldier_ Day of Reckoning-2012-1080p.mkv"
[20:56:04] CWD /G Movies/MOVIES/Movies (original)
[20:56:05] 250 OK. Current directory is /G Movies/MOVIES/Movies (original)
[20:56:05] PWD
[20:56:05] 257 "/G Movies/MOVIES/Movies (original)" is your current location
[20:56:05] Getting properties (Size) of "/G Movies/MOVIES/Movies (original)/Universal Soldier_ Day of Reckoning-2012-1080p.mkv"
[20:56:05] MLST Universal Soldier_ Day of Reckoning-2012-1080p.mkv
[20:56:05] 550 Can't check for file existence
[20:56:05] TYPE I
[20:56:05] 200 TYPE is now 8-bit binary
[20:56:05] SIZE Universal Soldier_ Day of Reckoning-2012-1080p.mkv
[20:56:05] Unable to obtain properties of file "/G Movies/MOVIES/Movies (original)/Universal Soldier_ Day of Reckoning-2012-1080p.mkv". Error=0x80070002
[20:56:05] PROT P
[20:56:05] 200 Data protection level set to "private"
[20:56:05] PASV
[20:56:05] 227 Entering Passive Mode (64,64,131,118,14,157)
[20:56:05] Opening data connection to 64.64.131.118 Port: 3741
[20:56:05] STOR Universal Soldier_ Day of Reckoning-2012-1080p.mkv
[20:56:05] 150 Accepted data connection
[19:24:38] 226-File successfully transferred
[19:24:38] 226 80899.360 seconds (measured here), 102.98 Kbytes per second
[19:24:38] 8531084060 bytes transferred. (102 KB/s) (22:28:33)
[19:24:38] Getting properties (Date modified) of "G:\MOVIES\Movies (original)\Universal Soldier_ Day of Reckoning-2012-1080p.mkv"
[19:24:38] Setting properties (Date modified) of "/G Movies/MOVIES/Movies (original)/Universal Soldier_ Day of Reckoning-2012-1080p.mkv"
[19:24:38] MFMT 20130619104831 Universal Soldier_ Day of Reckoning-2012-1080p.mkv
[19:24:39] 213 UTIME OK
[19:24:39] Getting properties (Size) of "G:\MOVIES\Movies (original)\Universal Soldier_ Day of Reckoning-2012-1080p.mkv"
[19:24:39] Using cached properties
[19:24:39] Getting properties (Size) of "/G Movies/MOVIES/Movies (original)/Universal Soldier_ Day of Reckoning-2012-1080p.mkv"
[19:24:39] MLST Universal Soldier_ Day of Reckoning-2012-1080p.mkv
[19:24:39] 250-Begin
[19:24:39]  type=file;size=4253057024;modify=20130619104831;UNIX.mode=0644;UNIX.uid=33;UNIX.gid=33;unique=1cgfffffff5367d1ade; Universal Soldier_ Day of Reckoning-2012-1080p.mkv
[19:24:39] 250 End.
[19:24:39] Source File Size=8531084060, Destination File Size=4253057024
[19:24:39] File size mismatch.
[19:24:39] Transfer failed.
[19:24:39] Operation End
[19:24:39] Initializing. Transfer Queue v5.0.1348.0.
[19:24:39] Operation Begin
[19:24:39] Getting properties (Date modified, Size) of "G:\MOVIES\Movies (original)\Universal Soldier_ Day of Reckoning-2012-1080p.mkv"
[19:24:39] 250 End.
[19:24:39] PASV
[19:24:39] 227 Entering Passive Mode (64,64,131,118,13,0)
[19:24:39] Opening data connection to 64.64.131.118 Port: 3328
[19:24:39] REST 4253057024
[19:24:39] 350 Restarting at 4253057024
[19:24:39] STOR Universal Soldier_ Day of Reckoning-2012-1080p.mkv
[19:24:39] 150 Accepted data connection
