Smartftp 4.0 backup to 5.0
Best Answer mb , 19 December 2013 - 01:28 AM
1. Extract the backup .zip file
2. Extract the Favorites.zip file
3. Copy the .xml files/folders into the %appdata%\SmartFTP\Client 2.0\Favorites folder.
Important: Do NOT import the .reg files inside the backup .zip Go to the full post
5 replies to this topic
#1 Jayleb
Jayleb
  • 4 posts
Posted 18 December 2013 - 11:44 AM
I have installed smartFTP 5.0.1349 on windows 8.1 and I only have my backup files that I exported in the 4.xxx version Backup tool. How can i restore favourites, layouts etc?
jay
Edited by Jayleb, 18 December 2013 - 11:45 AM.
  • 11935 posts
Posted 19 December 2013 - 01:28 AM   Best Answer
#3 Jayleb
Jayleb
  • 4 posts
Posted 22 December 2013 - 06:55 AM
Thanks for that. In regards to making backups in the new version, is the method below correct or is there a more simple way,
How To back up SmartFTP settings
SmartFTP saves the application data and the UI settings in the common places: Application Data Includes the favorites, custom commands and the transfer queue.
They are stored in the user's applicataion data folder: %appdata%\SmartFTP E.g. C:\Users\\AppData\Roaming
UI settings In the Windows regstry: Open regedit.exe Go to HKEY_CURRENT_USER\Software\SmartFTP Right-click on the key Select Export from the context menu The UI registry data might be machine specific and it is not recommended to move it from one machine to the other.
Edited by Jayleb, 22 December 2013 - 06:57 AM.
#4 Jayleb
Jayleb
  • 4 posts
Posted 14 January 2014 - 12:11 PM
Any chance at getting an answer to my question above. I have waited 3 weeks and these are the only questions I have asked in over 5 years of paid versions of Smart FTP. Just want to know the best way to back this up?
Jay
#5 mb
  • 11935 posts
Posted 14 January 2014 - 01:21 PM
Yes the method looks ok.
The simplest way is not to individually backup the data from each applications but to rely on the backup features provided by the operating system:
- Full system backup
http://windows.micro...s#1TC=windows-7
- File History in Windows 8
http://windows.micro...se-file-history
Or other 3rd party backup tools/products. E.g.
- Continous backup with WD My Passport external harddrive
#6 Jayleb
Jayleb
  • 4 posts
Posted 28 January 2014 - 01:31 PM
Thanks for the update on this.
Kind Regards
Jay
