Odd folder behavior
2 replies to this topic
#1 Brian.Hart
Brian.Hart
Posted 07 May 2013 - 01:17 PM
SmartFTP 4.0.1248.0
Windows 7 Pro 64-bit
I have this very annoying anomaly regarding interaction between SmartFTP and Windows 7 folders. To my Start Menu I have pinned a shortcut to a folder I use regularly. I open that folder from the Start Menu, drill down to a subfolder (by double-clicking through a couple layers of subfolders in the right pane), open an FTP folder in SmartFTP, and drag a file from SmartFTP to the open subfolder. The file does not go into the subfolder, but into the parent folder that was pinned to the Start Menu. If I instead open Windows Explorer and browse to that some subfolder, the file dragged from SmartFTP goes into the subfolder, not the parent.
I thought this was a Windows folder behavior issue but have tested this within Windows 7 itself by copying from my desktop to the subfolder--and the file correctly goes to the subfolder, regardless of how I open the folder structure.
So I conclude it is as though SmartFTP is somehow unaware that I have browsed beyond the folder opened by my shortcut.
  • 11960 posts
Posted 07 May 2013 - 03:15 PM
Did you test this with the latest version of SmartFTP?
#3 rtbd
rtbd
    Bangladesh
  • Interests:
    bloging
Posted 14 May 2013 - 08:20 PM
I think you will download the latest version can be used for your computer
