Connect failed. Error=0x80043112
5 replies to this topic
#1 stephen111
stephen111
Posted 08 April 2013 - 05:54 PM
I am receiving a 'Connect failed. Error=0x80043112' message when attempting to connect to an FTP host (21) using SmartFTP 4.1.1289.0 (Ultimate).
I have been able to successfully connect to other hosts from my machine so I don't think that it is a firewall issue on my side.
I am also able to connect to this specific host from another machine using SmartFTP 4.1.1289.0 (Pro).
Any suggestions?
Stephen Howard
  • 11975 posts
Posted 08 April 2013 - 06:25 PM
Please install the latest version:
Then contact support through the menu: Help->Request Support
#3 floele
floele
  • 7 posts
Posted 24 March 2014 - 05:31 PM
I got the same error now in 5.0.1353.0. Connecting to the server has always worked fine (and still works fine over putty), but fails with SmartFTP.
[18:28:43] SmartFTP v5.0.1353.0
[18:28:43] Resolving host name "xyz"
[18:28:43] Connecting to x.x.x.x Port: 22
[18:28:44] Connected to ....
[18:28:44] SSH protocol version reply. Client Id: SSH-2.0-SmartFTP
[18:28:44] SSH-2.0-OpenSSH_6.5
[18:28:44] Starting SSH session. Remote Id: "SSH-2.0-OpenSSH_6.5"
[18:28:44] Server Algorithm Suite
           Key Exchange: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
           Server Host Key: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256,ssh-ed25519
           Client to Server Encryption: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
           Server to Client Encryption: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
           Client to Server HMAC: hmac-md5-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-sha1,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
           Server to Client HMAC: hmac-md5-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-sha1,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
           Client to Server Compression: none,zlib@openssh.com
           Server to Client Compression: none,zlib@openssh.com
[18:28:44] Selected Algorithm Suite
           Server Host Key: ecdsa-sha2-nistp256
           Client to Server Encryption: aes128-gcm@openssh.com
           Server to Client Encryption: aes128-gcm@openssh.com
           Client to Server HMAC: none
           Server to Client HMAC: none
           Client to Server Compression: zlib@openssh.com
           Server to Client Compression: zlib@openssh.com
[18:28:44] Client Algorithm Suite
           Key Exchange: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,rsa1024-sha1
           Server Host Key: ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,x509v3-sign-rsa-sha1,x509v3-sign-dss-sha1,ssh-rsa,ssh-dss
           Client to Server Encryption: aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes256-ctr,aes256-cbc,rijndael256-cbc,rijndael-cbc@lysator.liu.se,aes192-ctr,aes192-cbc,rijndael192-cbc,aes128-ctr,aes128-cbc,rijndael128-cbc,3des-cbc,blowfish-cbc,cast128-cbc
           Server to Client Encryption: aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes256-ctr,aes256-cbc,rijndael256-cbc,rijndael-cbc@lysator.liu.se,aes192-ctr,aes192-cbc,rijndael192-cbc,aes128-ctr,aes128-cbc,rijndael128-cbc,3des-cbc,blowfish-cbc,cast128-cbc
           Client to Server HMAC: hmac-sha2-512,hmac-sha2-256,hmac-sha1,hmac-md5,umac-64@openssh.com,hmac-ripemd160
           Server to Client HMAC: hmac-sha2-512,hmac-sha2-256,hmac-sha1,hmac-md5,umac-64@openssh.com,hmac-ripemd160
           Client to Server Compression: zlib@openssh.com,zlib,none
           Server to Client Compression: zlib@openssh.com,zlib,none
[18:28:44] Key Exchange Algorithm: curve25519-sha256@libssh.org
[18:28:44] Server closed connection
[18:28:44] Connect failed. Error=0x80043112
[18:28:44] Waiting to retry (30s)...
Strange thing is that it does something with certificates here even though I only activated "passworc" as authentication mechanism and using keys would not work because I have none.
Edited by floele, 24 March 2014 - 05:32 PM.
  • 11975 posts
Posted 24 March 2014 - 06:39 PM
Contact support: menu: Help->Request support and send the server ip.
#5 Ferret
Ferret
  • 3 posts
Posted 10 April 2014 - 01:39 PM
I too am receiving this error.    Yet only since an update.   previous versions were running correctly.
"An established connection was aborted by the software in your host machine
Connect Failed.   Error=0x80043112
Running Win 7 64bit.
SmartFTP  5.0.1354.0
As requested by support I have uninstalled Firewall and Anti Virus.
Error still exists.
I cannot even connect to ftp.smartftp.com
I also cannot do a fresh install of Win 7 as I have no other computer available.
Any help gratefully received.
  • 11975 posts
Posted 10 April 2014 - 01:57 PM
The problems are unrelated. Closing this topic.
