Error uploading files! HELP
#1 jmaldo
jmaldo
Posted 16 January 2013 - 01:20 PM
Hello:
While trying to upload certain files to a FTP MVS running Z/OS Server there are certain error that appears.
Some of them are 501 command aborted -- FTP server not configured for SIZE and 501 command aborted -- FTP server not configured for MDTM . For some reason using another FTP client the uploading is a success, but when using SmartFTP Client, latest version, this error occurs. I will post the error log in here, but all of the files and ips will be erased for security reasons. Any help will be appreciated.
ERROR LOG:
[08:54:50] SmartFTP v4.1.1292.0
[08:54:50] Resolving host name "Server"
[08:54:50] Connecting to IP Port: 21
[08:54:51] Connected to Server.
[08:54:51] 220-FTPD1 IBM FTP CS V1R13 at Server, 07:56:41 on 2013-01-16.
[08:54:51] 220 Connection will close if idle for more than 1440 minutes.
[08:54:51] USER ******
[08:54:51] 331 Send password please.
[08:54:51] PASS (hidden)
[08:54:51] 230 ****** is logged on.  Working directory is "******.".
[08:54:51] SYST
[08:54:51] 215 MVS is the operating system of this server. FTP Server is running on z/OS.
[08:54:51] Detected Server Type: MVS
[08:54:51] RTT: 59.804 ms
[08:54:51] FEAT
[08:54:51] 211- Extensions supported
[08:54:51]  AUTH TLS
[08:54:52]  PBSZ
[08:54:52]  PROT
[08:54:52] 211 End
[08:54:52] Detected Server Software: z/OS
[08:54:52] TYPE I
[08:54:52] 200 Representation type is Image
[08:54:52] REST 0
[08:54:52] 504 Restart requires Block or Compressed transfer mode.
[08:54:52] PWD
[08:54:52] 257 "'******.'" is working directory.
[08:54:52] cwd
[08:54:52] 250 "*******." is the working directory name prefix.
[08:54:52] PWD
[08:54:52] 257 "'*******'" is working directory.
[08:54:52] CWD 'Directory'
[08:54:52] 250 "Directory" is the working directory name prefix.
[08:54:52] PWD
[08:54:52] 257 "'Directory'" is working directory.
[08:54:52] Ignoring LIST options.
[08:54:52] TYPE A
[08:54:52] 200 Representation type is Ascii NonPrint
[08:54:52] PASV
[08:54:52] 227 Entering Passive Mode (*******)
[08:54:52] Opening data connection to IP Port: 50069
[08:54:52] LIST
[08:54:52] 125 List started OK
[08:54:52] 381 bytes transferred. (6.30 KB/s) (59 ms)
[08:54:52] 250 List completed successfully.
[08:55:15] The operation has been added to the Transfer Queue. Check the Transfer Queue for the status.
[08:55:23] NOOP
[08:55:23] 200 OK
[08:55:53] NOOP
[08:55:54] 200 OK
[08:56:24] NOOP
[08:56:24] 200 OK
[08:56:54] NOOP
[08:56:54] 200 OK
[08:57:25] NOOP
[08:57:25] 200 OK
[08:57:55] NOOP
[08:57:55] 200 OK
[08:58:25] NOOP
[08:58:25] 200 OK
[08:58:35] TYPE I
[08:58:35] 200 Representation type is Image
[08:58:35] SIZE File
[08:58:35] 501 command aborted -- FTP server not configured for SIZE
[08:58:35] MDTM File
[08:58:35] 501 command aborted -- FTP server not configured for MDTM
[08:58:35] STAT File
[08:58:35] 504 STAT file-identifier: not implemented
[08:58:35] The operation has been added to the Transfer Queue. Check the Transfer Queue for the status.
[08:58:37] SIZE File
[08:58:37] 501 command aborted -- FTP server not configured for SIZE
[08:58:37] MDTM File
[08:58:37] 501 command aborted -- FTP server not configured for MDTM
[08:58:37] Obtaining file information (size/date) from directory listing.
[08:58:37] Ignoring LIST options.
[08:58:37] TYPE A
[08:58:37] 200 Representation type is Ascii NonPrint
[08:58:37] PASV
[08:58:37] 227 Entering Passive Mode (******)
[08:58:37] Opening data connection to IP Port: 50057
[08:58:37] LIST
[08:58:37] 125 List started OK
[08:58:37] 381 bytes transferred. (6.00 KB/s) (62 ms)
[08:58:38] 250 List completed successfully.
[08:58:38] File "File" not found in directory listing.
[08:59:08] TYPE I
[08:59:08] 200 Representation type is Image
[08:59:08] SIZE File
[08:59:08] 501 command aborted -- FTP server not configured for SIZE
[08:59:08] MDTM File
[08:59:08] 501 command aborted -- FTP server not configured for MDTM
[08:59:08] Obtaining file information (size/date) from directory listing.
[08:59:08] Ignoring LIST options.
[08:59:08] TYPE A
[08:59:09] 200 Representation type is Ascii NonPrint
[08:59:09] PASV
[08:59:09] 227 Entering Passive Mode (*******)
[08:59:09] Opening data connection to IP Port: 50063
[08:59:09] LIST
[08:59:09] 125 List started OK
[08:59:09] 381 bytes transferred. (2.43 KB/s) (153 ms)
[08:59:10] 250 List completed successfully.
[08:59:10] File "File" not found in directory listing.
[08:59:39] TYPE I
[08:59:39] 200 Representation type is Image
[08:59:39] SIZE File
[08:59:39] 501 command aborted -- FTP server not configured for SIZE
[08:59:39] MDTM File
[08:59:40] 501 command aborted -- FTP server not configured for MDTM
[08:59:40] Obtaining file information (size/date) from directory listing.
[08:59:40] Ignoring LIST options.
[08:59:40] TYPE A
[08:59:40] 200 Representation type is Ascii NonPrint
[08:59:40] PASV
[08:59:40] 227 Entering Passive Mode (********)
[08:59:40] Opening data connection to IP Port: 50046
[08:59:40] LIST
[08:59:41] 125 List started OK
[08:59:41] 381 bytes transferred. (3.61 KB/s) (103 ms)
[08:59:41] 250 List completed successfully.
[08:59:41] File "File" not found in directory listing.
[09:00:09] TYPE I
[09:00:09] 200 Representation type is Image
[09:00:09] SIZE File
[09:00:09] 501 command aborted -- FTP server not configured for SIZE
[09:00:09] MDTM File
[09:00:09] 501 command aborted -- FTP server not configured for MDTM
[09:00:09] Obtaining file information (size/date) from directory listing.
[09:00:09] Ignoring LIST options.
[09:00:09] TYPE A
[09:00:10] 200 Representation type is Ascii NonPrint
[09:00:10] PASV
[09:00:10] 227 Entering Passive Mode (*********)
[09:00:10] Opening data connection to IP Port: 50079
[09:00:10] LIST
[09:00:10] 125 List started OK
[09:00:10] 381 bytes transferred. (5.90 KB/s) (63 ms)
[09:00:10] 250 List completed successfully.
[09:00:10] File "File" not found in directory listing.
[09:00:40] NOOP
[09:00:40] 200 OK
[09:00:40] TYPE I
[09:00:40] 200 Representation type is Image
[09:00:40] SIZE File
[09:00:40] 501 command aborted -- FTP server not configured for SIZE
[09:00:40] MDTM File
[09:00:40] 501 command aborted -- FTP server not configured for MDTM
[09:00:40] Obtaining file information (size/date) from directory listing.
[09:00:40] Ignoring LIST options.
[09:00:40] TYPE A
[09:00:40] 200 Representation type is Ascii NonPrint
[09:00:40] PASV
[09:00:40] 227 Entering Passive Mode (*******)
[09:00:40] Opening data connection to IP Port: 50065
[09:00:40] LIST
[09:00:41] 125 List started OK
[09:00:41] 381 bytes transferred. (6.20 KB/s) (60 ms)
[09:00:41] 250 List completed successfully.
[09:00:41] File "File" not found in directory listing.
[09:01:10] TYPE I
[09:01:11] 200 Representation type is Image
[09:01:11] SIZE File
[09:01:11] 501 command aborted -- FTP server not configured for SIZE
[09:01:11] MDTM File
[09:01:11] 501 command aborted -- FTP server not configured for MDTM
[09:01:11] Obtaining file information (size/date) from directory listing.
[09:01:11] Ignoring LIST options.
[09:01:11] TYPE A
[09:01:11] 200 Representation type is Ascii NonPrint
[09:01:11] PASV
[09:01:11] 227 Entering Passive Mode (********)
[09:01:11] Opening data connection to IP Port: 50092
[09:01:11] LIST
[09:01:11] 125 List started OK
[09:01:11] 381 bytes transferred. (6.09 KB/s) (61 ms)
[09:01:11] 250 List completed successfully.
[09:01:11] File "File" not found in directory listing.
[09:01:42] TYPE I
[09:01:42] 200 Representation type is Image
[09:01:42] SIZE File
[09:01:42] 501 command aborted -- FTP server not configured for SIZE
[09:01:42] MDTM File
[09:01:42] 501 command aborted -- FTP server not configured for MDTM
[09:01:42] Obtaining file information (size/date) from directory listing.
[09:01:42] Ignoring LIST options.
[09:01:42] TYPE A
[09:01:42] 200 Representation type is Ascii NonPrint
[09:01:42] PASV
[09:01:42] 227 Entering Passive Mode (********)
[09:01:42] Opening data connection to IP Port: 50023
[09:01:42] LIST
[09:01:42] 125 List started OK
[09:01:42] 381 bytes transferred. (6.30 KB/s) (59 ms)
[09:01:42] 250 List completed successfully.
[09:01:42] File "File" not found in directory listing.
[09:02:13] NOOP
[09:02:13] 200 OK
[09:02:14] TYPE I
[09:02:14] 200 Representation type is Image
[09:02:14] SIZE File
[09:02:15] 501 command aborted -- FTP server not configured for SIZE
[09:02:15] MDTM File
[09:02:15] 501 command aborted -- FTP server not configured for MDTM
[09:02:15] Obtaining file information (size/date) from directory listing.
[09:02:15] Ignoring LIST options.
[09:02:15] TYPE A
[09:02:15] 200 Representation type is Ascii NonPrint
[09:02:15] PASV
[09:02:15] 227 Entering Passive Mode (********)
[09:02:15] Opening data connection to IP Port: 50006
[09:02:15] LIST
[09:02:15] 125 List started OK
[09:02:15] 381 bytes transferred. (5.47 KB/s) (68 ms)
[09:02:15] 250 List completed successfully.
[09:02:15] File "File" not found in directory listing.
[09:02:44] TYPE I
[09:02:45] 200 Representation type is Image
[09:02:45] SIZE File
[09:02:45] 501 command aborted -- FTP server not configured for SIZE
[09:02:45] MDTM File
[09:02:45] 501 command aborted -- FTP server not configured for MDTM
[09:02:45] Obtaining file information (size/date) from directory listing.
[09:02:45] Ignoring LIST options.
[09:02:45] TYPE A
[09:02:45] 200 Representation type is Ascii NonPrint
[09:02:45] PASV
[09:02:45] 227 Entering Passive Mode (**********)
[09:02:45] Opening data connection to IP Port: 50075
[09:02:45] LIST
[09:02:45] 125 List started OK
[09:02:45] 381 bytes transferred. (6.20 KB/s) (60 ms)
[09:02:45] 250 List completed successfully.
[09:02:45] File "File" not found in directory listing.
Thank You
  • 11935 posts
Posted 16 January 2013 - 01:46 PM
Please contact support:
https://www.smartftp...port-f2653.html
And send the complete log from the transfer: double click the file in the transfer queue.
