Remote resetting connection on very large files
10 replies to this topic
#1 amckern
amckern
  • 7 posts
Posted 07 January 2013 - 12:13 PM
I am attempting to upload around 10x 2-12GB files (FakeFactory's mod for Half-Life 2), however the remote keeps reseting the connection, and pause/resume of the file list restarts the upload from 0mb.
I have managed to upload a 780mb file to this provider duing the same time frame i have been trying to upload these GB sized files
Is there a setting i can use on the registered home user that might be able to keep the connection alive longer?
Thanks!
#2 SimplySimon
SimplySimon
Posted 09 January 2013 - 06:24 PM
I had a similar problem. I turned out to be a limit set by the receiving server. My files were image files so I saved them as jpg's the oly way I can think of is using a series of zip files which can then be re-stitched together. Hope this helps
#3 mb
  • 11971 posts
Posted 09 January 2013 - 06:29 PM
Post the transfer log here: Double click the file in the transfer queue
#4 amckern
amckern
  • 7 posts
Posted 10 January 2013 - 08:51 AM
I'll see what i can do about the transfer list when i try and upload again tonight.
In terms of making the file smaller, i would love to upload them as part files but i dont have SSH access to use putty, or the smart ftp SSH functionailty to stich them.
#5 amckern
amckern
  • 7 posts
Posted 10 January 2013 - 08:04 PM
Looks like the file is failing CRC checks after 2-4hrs of upload...
[22:36:45] Operation Begin
[22:36:45] Resolving host name "ftp.ammahls.com"
[22:36:45] Connecting to 216.97.239.90 Port: 21
[22:36:45] Connected to ftp.ammahls.com.
[22:36:45] 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
[22:36:45] 220-You are user number 4 of 50 allowed.
[22:36:45] 220-Local time is now 04:36. Server port: 21.
[22:36:45] 220-IPv6 connections are also welcome on this server.
[22:36:45] 220 You will be disconnected after 15 minutes of inactivity.
[22:36:45] USER amckern0
[22:36:45] 331 User amckern0 OK. Password required
[22:36:45] PASS (hidden)
[22:36:46] 230 OK. Current restricted directory is /
[22:36:46] SYST
[22:36:46] 215 UNIX Type: L8
[22:36:46] Detected Server Type: UNIX
[22:36:46] RTT: 183.891 ms
[22:36:46] FEAT
[22:36:46] 211-Extensions supported:
[22:36:46]  EPRT
[22:36:46]  IDLE
[22:36:46]  MDTM
[22:36:46]  SIZE
[22:36:46]  MFMT
[22:36:46]  REST STREAM
[22:36:46]  MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[22:36:46]  MLSD
[22:36:46]  AUTH TLS
[22:36:46]  PBSZ
[22:36:46]  PROT
[22:36:46]  ESTA
[22:36:46]  PASV
[22:36:46]  EPSV
[22:36:46]  SPSV
[22:36:46]  ESTP
[22:36:46] 211 End.
[22:36:46] Detected Server Software: PureFTPd
[22:36:46] PWD
[22:36:46] 257 "/" is your current location
[22:36:46] CWD /public_html/downloads/fakefactory/4
[22:36:46] 250 OK. Current directory is /public_html/downloads/fakefactory/4
[22:36:46] PWD
[22:36:47] 257 "/public_html/downloads/fakefactory/4" is your current location
[22:36:47] Remote file exist check: "cm4op1.7z".
[22:36:47] MLST cm4op1.7z
[22:36:47] 250-Begin
[22:36:47]  type=file;size=436797440;modify=20121221123515;UNIX.mode=0644;UNIX.uid=32318;UNIX.gid=32320;unique=808g61f4013; cm4op1.7z
[22:36:47] 250 End.
[22:36:47] Source File: Size=2753655479, Date Modified=2012-12-21T12:35:15
[22:36:47] Destination File: Size=436797440, Date Modified=2012-12-21T12:35:15
[22:36:47] RecentTime=2013-01-10T08:49:28
[22:36:47] Rule "IF Destination Time=Equal AND Size=Smaller AND Transfer=No Matter THEN Resume" matched. Action="Resume".
[22:36:47] TYPE I
[22:36:47] 200 TYPE is now 8-bit binary
[22:36:47] PASV
[22:36:47] 227 Entering Passive Mode (216,97,239,90,120,1)
[22:36:47] Opening data connection to 216.97.239.90 Port: 30721
[22:36:47] REST 436797440
[22:36:47] 350 Restarting at 436797440
[22:36:47] STOR cm4op1.7z
[22:36:48] 150 Accepted data connection
[22:36:54] Data error (cyclic redundancy check).
[22:36:54] 0 bytes transferred. (0 bytes/s) (00:00:06)
[22:36:54] Transfer failed.
[22:36:54] Operation End
[22:37:24] Operation Begin
[22:37:24] Remote file exist check: "cm4op1.7z".
[22:37:24] MLST cm4op1.7z
[22:37:24] 250-Begin
[22:37:24]  type=file;size=436797440;modify=20121221123515;UNIX.mode=0644;UNIX.uid=32318;UNIX.gid=32320;unique=808g2bf1706; cm4op1.7z
[22:37:24] 250 End.
[22:37:24] Source File: Size=2753655479, Date Modified=2012-12-21T12:35:15
[22:37:24] Destination File: Size=436797440, Date Modified=2012-12-21T12:35:15
[22:37:24] RecentTime=2013-01-10T11:36:54
[22:37:24] Rule "IF Destination Time=Equal AND Size=Smaller AND Transfer=No Matter THEN Resume" matched. Action="Resume".
[22:37:24] PASV
[22:37:24] 227 Entering Passive Mode (216,97,239,90,45,29)
[22:37:24] Opening data connection to 216.97.239.90 Port: 11549
[22:37:24] REST 436797440
[22:37:25] 350 Restarting at 436797440
[22:37:25] STOR cm4op1.7z
[22:37:25] 150 Accepted data connection
[22:37:31] Data error (cyclic redundancy check).
[22:37:31] 0 bytes transferred. (0 bytes/s) (00:00:06)
[22:37:31] Transfer failed.
[22:37:31] Operation End
[02:17:15] Operation Begin
[02:17:15] Resolving host name "ftp.ammahls.com"
[02:17:16] Connecting to 216.97.239.90 Port: 21
[02:17:16] Connected to ftp.ammahls.com.
[02:17:16] 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
[02:17:16] 220-You are user number 5 of 50 allowed.
[02:17:16] 220-Local time is now 08:17. Server port: 21.
[02:17:16] 220-IPv6 connections are also welcome on this server.
[02:17:16] 220 You will be disconnected after 15 minutes of inactivity.
[02:17:16] USER amckern0
[02:17:17] 331 User amckern0 OK. Password required
[02:17:17] PASS (hidden)
[02:17:17] 230 OK. Current restricted directory is /
[02:17:17] SYST
[02:17:17] 215 UNIX Type: L8
[02:17:17] Detected Server Type: UNIX
[02:17:17] RTT: 228.906 ms
[02:17:17] FEAT
[02:17:18] 211-Extensions supported:
[02:17:18]  EPRT
[02:17:18]  IDLE
[02:17:18]  MDTM
[02:17:18]  SIZE
[02:17:18]  MFMT
[02:17:18]  REST STREAM
[02:17:18]  MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[02:17:18]  MLSD
[02:17:18]  AUTH TLS
[02:17:18]  PBSZ
[02:17:18]  PROT
[02:17:18]  ESTA
[02:17:18]  PASV
[02:17:18]  EPSV
[02:17:18]  SPSV
[02:17:18]  ESTP
[02:17:18] 211 End.
[02:17:18] Detected Server Software: PureFTPd
[02:17:18] PWD
[02:17:18] 257 "/" is your current location
[02:17:18] CWD /public_html/downloads/fakefactory/4
[02:17:18] 250 OK. Current directory is /public_html/downloads/fakefactory/4
[02:17:18] PWD
[02:17:19] 257 "/public_html/downloads/fakefactory/4" is your current location
[02:17:19] Remote file exist check: "cm4op1.7z".
[02:17:19] MLST cm4op1.7z
[02:17:19] 250-Begin
[02:17:19]  type=file;size=436797440;modify=20121221123515;UNIX.mode=0644;UNIX.uid=32318;UNIX.gid=32320;unique=808g61f4013; cm4op1.7z
[02:17:19] 250 End.
[02:17:19] Source File: Size=2753655479, Date Modified=2012-12-21T12:35:15
[02:17:19] Destination File: Size=436797440, Date Modified=2012-12-21T12:35:15
[02:17:19] RecentTime=2013-01-10T11:37:31
[02:17:19] Rule "IF Destination Time=Equal AND Size=Smaller AND Transfer=No Matter THEN Resume" matched. Action="Resume".
[02:17:19] TYPE I
[02:17:20] 200 TYPE is now 8-bit binary
[02:17:20] PASV
[02:17:20] 227 Entering Passive Mode (216,97,239,90,16,147)
[02:17:20] Opening data connection to 216.97.239.90 Port: 4243
[02:17:20] REST 436797440
[02:17:21] 350 Restarting at 436797440
[02:17:21] STOR cm4op1.7z
[02:17:21] 150 Accepted data connection
[02:17:28] Data error (cyclic redundancy check).
[02:17:28] 0 bytes transferred. (0 bytes/s) (00:00:06)
[02:17:28] Transfer failed.
[02:17:28] Operation End
[04:09:09] Operation Begin
[04:09:10] Resolving host name "ftp.ammahls.com"
[04:09:10] Connecting to 216.97.239.90 Port: 21
[04:09:10] Connected to ftp.ammahls.com.
[04:09:11] 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
[04:09:11] 220-You are user number 4 of 50 allowed.
[04:09:11] 220-Local time is now 10:09. Server port: 21.
[04:09:11] 220-IPv6 connections are also welcome on this server.
[04:09:11] 220 You will be disconnected after 15 minutes of inactivity.
[04:09:11] USER amckern0
[04:09:11] 331 User amckern0 OK. Password required
[04:09:11] PASS (hidden)
[04:09:11] 230 OK. Current restricted directory is /
[04:09:11] SYST
[04:09:12] 215 UNIX Type: L8
[04:09:12] Detected Server Type: UNIX
[04:09:12] RTT: 256.685 ms
[04:09:12] FEAT
[04:09:12] 211-Extensions supported:
[04:09:12]  EPRT
[04:09:12]  IDLE
[04:09:12]  MDTM
[04:09:12]  SIZE
[04:09:12]  MFMT
[04:09:12]  REST STREAM
[04:09:12]  MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[04:09:12]  MLSD
[04:09:12]  AUTH TLS
[04:09:12]  PBSZ
[04:09:12]  PROT
[04:09:12]  ESTA
[04:09:12]  PASV
[04:09:12]  EPSV
[04:09:12]  SPSV
[04:09:12]  ESTP
[04:09:12] 211 End.
[04:09:12] Detected Server Software: PureFTPd
[04:09:12] PWD
[04:09:12] 257 "/" is your current location
[04:09:12] CWD /public_html/downloads/fakefactory/4
[04:09:13] 250 OK. Current directory is /public_html/downloads/fakefactory/4
[04:09:13] PWD
[04:09:13] 257 "/public_html/downloads/fakefactory/4" is your current location
[04:09:13] Remote file exist check: "cm4op1.7z".
[04:09:13] MLST cm4op1.7z
[04:09:14] 250-Begin
[04:09:14]  type=file;size=436797440;modify=20121221123515;UNIX.mode=0644;UNIX.uid=32318;UNIX.gid=32320;unique=808g61f4013; cm4op1.7z
[04:09:14] 250 End.
[04:09:14] Source File: Size=2753655479, Date Modified=2012-12-21T12:35:15
[04:09:14] Destination File: Size=436797440, Date Modified=2012-12-21T12:35:15
[04:09:14] RecentTime=2013-01-10T15:17:28
[04:09:14] Rule "IF Destination Time=Equal AND Size=Smaller AND Transfer=No Matter THEN Resume" matched. Action="Resume".
[04:09:14] TYPE I
[04:09:14] 200 TYPE is now 8-bit binary
[04:09:14] PASV
[04:09:14] 227 Entering Passive Mode (216,97,239,90,23,221)
[04:09:14] Opening data connection to 216.97.239.90 Port: 6109
[04:09:14] REST 436797440
[04:09:15] 350 Restarting at 436797440
[04:09:15] STOR cm4op1.7z
[04:09:15] 150 Accepted data connection
[04:09:21] Data error (cyclic redundancy check).
[04:09:21] 0 bytes transferred. (0 bytes/s) (00:00:06)
[04:09:21] Transfer failed.
[04:09:21] Operation End
Edited by amckern, 10 January 2013 - 08:08 PM.
  • 11971 posts
Posted 10 January 2013 - 08:40 PM
For some reason the server believes that there is a data error:
Try to contact the server admin for assistance.
#7 amckern
amckern
  • 7 posts
Posted 14 January 2013 - 08:35 PM
I contcated my webhost, and they advised to use another file client like ytr- i have managed to upload 12GB's over the last 48hrs with no CRC errors, so i suspect either my install is broken, or the SmartFTP client is having trouble with CRC hashes on very large files?
  • 11971 posts
Posted 14 January 2013 - 09:53 PM
The problem is not with SmartFTP. Maybe your software firewall causes the problem.
#9 mbeijen
mbeijen
Posted 26 January 2013 - 02:49 PM
I am having the same issue.
Downloading a bunch of files from websites. All the small files (less than 10 Mb), no problem. Files over that size, transfer will try to start, but gets disconnected.
When trying a different FTP solution, no problems. All files get transfered.
Firewall on/off doesn't fix the issue.
I am using 4.1.1289.0
#10 mb
  • 11971 posts
Posted 29 January 2013 - 02:17 AM
Please try it again with the latest version: http://www.smartftp.com/download
#11 amckern
amckern
  • 7 posts
Posted 11 June 2013 - 10:01 AM
Hi Guys,
After a while i started hvaing trouble with FileZilla (The other client that was recomended) i brought a E.O.P., and managed to upload the remaning 23GB with no trouble, i suspect that my wireless connection to the router was the trouble.
