Copy file not working
2 replies to this topic
#1 syfer
syfer
Posted 15 October 2012 - 01:42 PM
Hi I am trying to copy my back up but its not working with the trail version its tells me this
"[14:31:49] SmartFTP v4.1.1277.0
[14:31:49] Resolving host name "ftp.mobilemarketingutopia.com"
[14:31:49] Connecting to 96.125.166.34 Port: 21
[14:31:49] Connected to ftp.mobilemarketingutopia.com.
[14:31:49] 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
[14:31:49] 220-You are user number 5 of 50 allowed.
[14:31:49] 220-Local time is now 08:31. Server port: 21.
[14:31:49] 220 You will be disconnected after 15 minutes of inactivity.
[14:31:49] USER csgknyio
[14:31:49] 331 User csgknyio OK. Password required
[14:31:49] PASS (hidden)
[14:31:49] 230 OK. Current restricted directory is /
[14:31:49] SYST
[14:31:49] 215 UNIX Type: L8
[14:31:49] Detected Server Type: UNIX
[14:31:49] RTT: 148.304 ms
[14:31:49] FEAT
[14:31:50] 211-Extensions supported:
[14:31:50] EPRT
[14:31:50] IDLE
[14:31:50] MDTM
[14:31:50] SIZE
[14:31:50] MFMT
[14:31:50] REST STREAM
[14:31:50] MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[14:31:50] MLSD
[14:31:50] AUTH TLS
[14:31:50] PBSZ
[14:31:50] PROT
[14:31:50] ESTA
[14:31:50] PASV
[14:31:50] EPSV
[14:31:50] SPSV
[14:31:50] ESTP
[14:31:50] 211 End.
[14:31:50] Detected Server Software: PureFTPd
[14:31:50] PWD
[14:31:50] 257 "/" is your current location
[14:31:50] TYPE A
[14:31:50] 200 TYPE is now ASCII
[14:31:50] PASV
[14:31:50] 227 Entering Passive Mode (96,125,166,34,185,169)
[14:31:50] Opening data connection to 96.125.166.34 Port: 47529
[14:31:50] MLSD
[14:31:50] 150 Accepted data connection
[14:31:50] 226-Options: -a -l
[14:31:50] 226 34 matches total
[14:31:50] 3926 bytes transferred. (24.5 KB/s) (156 ms)
[14:31:50] TYPE I
[14:31:50] 200 TYPE is now 8-bit binary
[14:31:50] SIZE access-logs
[14:31:51] 550 I can only retrieve regular files
[14:31:51] CWD /access-logs
[14:31:51] 250 OK. Current directory is /access-logs
[14:31:51] PWD
[14:31:51] 257 "/access-logs" is your current location
[14:31:51] CWD /
[14:31:51] PWD
[14:31:51] 257 "/" is your current location
[14:31:51] SIZE www
[14:31:51] CWD /www
[14:31:52] 250 OK. Current directory is /www
[14:31:52] PWD
[14:31:52] 257 "/www" is your current location
[14:31:59] CWD /subdomain
[14:31:59] 250 OK. Current directory is /subdomain
[14:31:59] PWD
[14:32:00] 257 "/subdomain" is your current location
[14:32:00] TYPE A
[14:32:00] 200 TYPE is now ASCII
[14:32:00] PASV
[14:32:00] 227 Entering Passive Mode (96,125,166,34,125,1)
[14:32:00] Opening data connection to 96.125.166.34 Port: 32001
[14:32:00] MLSD
[14:32:00] 1194 bytes transferred. (7.47 KB/s) (156 ms)
[14:32:00] 150 Accepted data connection
[14:32:00] 226-Options: -a -l
[14:32:00] 226 11 matches total
[14:32:02] CWD /subdomain/pp
[14:32:02] 250 OK. Current directory is /subdomain/pp
[14:32:02] PWD
[14:32:02] 257 "/subdomain/pp" is your current location
[14:32:02] PASV
[14:32:03] 227 Entering Passive Mode (96,125,166,34,175,233)
[14:32:03] Opening data connection to 96.125.166.34 Port: 45033
[14:32:03] MLSD
[14:32:03] 150 Accepted data connection
[14:32:03] 226-Options: -a -l
[14:32:03] 226 7 matches total
[14:32:03] 799 bytes transferred. (5.00 KB/s) (156 ms)
[14:32:24] CWD /MyWebsitesBackUp
[14:32:24] 250 OK. Current directory is /MyWebsitesBackUp
[14:32:24] PWD
[14:32:24] 257 "/MyWebsitesBackUp" is your current location
[14:32:24] PASV
[14:32:24] 227 Entering Passive Mode (96,125,166,34,138,60)
[14:32:24] Opening data connection to 96.125.166.34 Port: 35388
[14:32:24] MLSD
[14:32:24] 150 Accepted data connection
[14:32:24] 226-Options: -a -l
[14:32:24] 226 4 matches total
[14:32:24] 440 bytes transferred. (2.75 KB/s) (156 ms)
[14:32:25] CWD /MyWebsitesBackUp/mywebsite
[14:32:26] 250 OK. Current directory is /MyWebsitesBackUp/mywebsite
[14:32:26] PWD
[14:32:26] 257 "/MyWebsitesBackUp/mywebsite" is your current location
[14:32:26] PASV
[14:32:26] 227 Entering Passive Mode (96,125,166,34,178,229)
[14:32:26] Opening data connection to 96.125.166.34 Port: 45797
[14:32:26] MLSD
[14:32:26] 334 bytes transferred. (2.09 KB/s) (156 ms)
[14:32:26] 150 Accepted data connection
[14:32:26] 226-Options: -a -l
[14:32:26] 226 3 matches total
[14:32:30] CWD /MyWebsitesBackUp/mywebsite/26 september 2012
[14:32:31] 250 OK. Current directory is /MyWebsitesBackUp/mywebsite/26 september 2012
[14:32:31] PWD
[14:32:31] 257 "/MyWebsitesBackUp/mywebsite/26 september 2012" is your current location
[14:32:31] DELE blog_backup.zip
[14:32:31] 550 Could not delete blog_backup.zip: No such file or directory
[14:32:39] DELE blog_backup.zip
[14:32:39] 550 Could not delete blog_backup.zip: No such file or directory
[14:32:48] MLST blog_backup.zip
[14:32:48] 550 Can't check for file existence
[14:32:48] The operation has been added to the Transfer Queue. Check the Transfer Queue for the status.
[14:32:51] MLST blog_backup.zip
[14:32:51] 550 Can't check for file existence
[14:33:21] NOOP
[14:33:21] 200 Zzz...
[14:33:23] MLST blog_backup.zip
[14:33:23] 550 Can't check for file existence
[14:33:55] MLST blog_backup.zip
[14:33:55] 550 Can't check for file existence
[14:34:27] MLST blog_backup.zip
[14:34:27] 550 Can't check for file existence"
Can you please help I need to copy my back up zip and its 890mb to another location on my server can you help me is their a bug in this version?
  • 11953 posts
Posted 15 October 2012 - 02:49 PM
Please contact support:
https://www.smartftp...port-f2653.html
#3 syfer
syfer
Posted 15 October 2012 - 05:17 PM
Hi I can not do that it told me i need a license but i am using the trail version to see if it would work since it does not i thought i contact you on the form support.
Edited by syfer, 15 October 2012 - 05:19 PM.
