File exists Check fails > Scheduled Task uploads same file again and again
MLST 550 Unicode Schedule
3 replies to this topic
#1 eini
eini
Posted 28 October 2011 - 06:52 AM
Hi There,
I'm trying to achieve a Weekly (for some files daily) Backup via Scheduled Jobs in SmartFTP to a remote ftp(es) Site, no Problems so far, the first few test-backups ran fine, but i wondered why so much Data is transferred. The amount of Data changed in 24h should not be that much ...
(additional point is, that if the whole amount of Data will be transferred every time the Backup would take more than 24h and the next Scheduled Job would go off, ergo one Backup would be older than 24h -> not good :o )
So took a closer look in the Log-files (Gene6FTP-Server (3.10.x) and SmartFTP-Client (4.0.12xx)) and found many "unnecessary" File transfers.
Here an cleaned example Log-file (Client-Side) for one File. There definitely will be Filnames containing Unicode Characters (蘇), German Characters like ö and some from languages i don't even know ^^ (like ð or æ). In this Log the file exists on the server and is displayed correctly (has exaclty the same size, Date, etc), as synchronization method i've selected one way with delete, the file exists rules should prevent transmission of the file (played around with hash-comparison and rules), but every time files like these get retransmitted, if changed or not ;)
[07:58:33] Operation Begin
[07:58:33] Resolving host name "servername@customer.de"
[07:58:33] Connecting to servername Port: 990
[07:58:33] Connected to servername.
[07:58:33] 220 Gene6 FTP Server v3.10.0 (Build 2) ready...
[07:58:33] AUTH TLS
[07:58:33] 234 AUTH command ok; starting SSL connection.
[07:58:33] TLS 1.0 encrypted session established.
[07:58:33] Key Exchange: 1024 bit RSA
[07:58:33] Session Cipher: 128 bit RC4
[07:58:33] Command channel protection set to Private.
[07:58:33] PBSZ 0
[07:58:33] 200 PBSZ=0
[07:58:33] USER XXXXXXX
[07:58:33] 331 Password required for XXXXXX.
[07:58:33] PASS (hidden)
[07:58:33] 230 User XXXXXX logged in.
[07:58:33] SYST
[07:58:33] 215 UNIX Type: L8
[07:58:33] Detected Server Type: UNIX
[07:58:33] RTT: 56.558 ms
[07:58:33] FEAT
[07:58:34] 211-Extensions supported:
[07:58:34]  AUTH TLS
[07:58:34]  CCC
[07:58:34]  CLNT
[07:58:34]  CPSV
[07:58:34]  EPRT
[07:58:34]  EPSV
[07:58:34]  MDTM
[07:58:34]  MFCT
[07:58:34]  MFMT
[07:58:34]  MLST type*;size*;create;modify*;
[07:58:34]  MODE Z
[07:58:34]  PASV
[07:58:34]  PBSZ
[07:58:34]  PROT
[07:58:34]  REST STREAM
[07:58:34]  SIZE
[07:58:34]  SSCN
[07:58:34]  TVFS
[07:58:34]  UTF8
[07:58:34]  XCRC "filename" SP EP
[07:58:34]  XMD5 "filename" SP EP
[07:58:34]  XSHA1 "filename" SP EP
[07:58:34] 211 End.
[07:58:34] CLNT SmartFTP 4.0.1207.0
[07:58:34] 200 Noted.
[07:58:34] OPTS UTF8 ON
[07:58:34] 200 UTF8 OPTS ON
[07:58:34] OPTS MLST type;size;create;modify;
[07:58:34] 200 MLST OPTS type;size;create;modify;
[07:58:34] Detected Server Software: Gene6 FTP Server
[07:58:34] PWD
[07:58:34] 257 "/" is current directory.
[07:58:34] CWD /data/backup/test!
[07:58:34] 250 CWD command successful. "/data/backup/test!" is current directory.
[07:58:34] PWD
[07:58:34] 257 "/data/backup/test!" is current directory.
[07:58:34] Remote file exist check: "test蘇å·Âžå¤ÂÂœ曲.mp3".
[07:58:34] MLST test蘇å·Âžå¤ÂÂœ曲.mp3
[07:58:34] 550 File or directory not found.
[07:58:34] Compression disabled. File "test蘇å·Âžå¤ÂÂœ曲.mp3" matches exception "*.mp3".
[07:58:34] TYPE I
[07:58:34] 200 Type set to I.
[07:58:34] PROT P
[07:58:34] 200 PROT command successful.
[07:58:34] PASV
[07:58:34] 227 Entering Passive Mode (XXXXXXX)
[07:58:34] Opening data connection to IPXXX Port: XXXX
[07:58:34] STOR test蘇å·Âžå¤ÂÂœ曲.mp3
[07:58:34] 150 Data connection accepted from 93.219.214.179:1051; transfer starting for /data/backup/test!/test蘇å·Âžå¤ÂÂœ曲.mp3
[07:58:37] 1446487 bytes transferred. (505 KB/s) (00:00:02)
[07:58:37] 226 File received ok.
[07:58:37] MFMT 20110622174809 test蘇å·Âžå¤ÂÂœ曲.mp3
[07:58:37] 213 Modify=20110622174809; test????.mp3
[07:58:37] MFCT 20101226231807 test蘇å·Âžå¤ÂÂœ曲.mp3
[07:58:37] 213 Create=20101226231807; test????.mp3
[07:58:37] MLST test蘇å·Âžå¤ÂÂœ曲.mp3
[07:58:37] 550 File or directory not found.
[07:58:37] File not found. Skipping file exist check.
[07:58:37] Operation End
Ah in the preview i just saw that the unicode-characters are not displayed correctly, so here's a screenshot of the filename in the example-log above
Posted Image
Funny thing is ... i tried the same file with filezilla or totalcommander (same connection used), both comapares filesize (and / or date if wanted) and skips the example-file as desired.
How do i achieve this behaviour with smartftp?
Thanks in Advance!
Edit says: Some System-key-data:
Source-System: Smartftp-Client 4.0.12xx
Windows Server 2003 R1 SP1 x86
aditional-language support, system-language option: german
Target-System: Gene6 FTP 3.10.xx
Windows Server 2003 R2 (i think x86, not sure)
no additional language support, system language option: german
Edited by eini, 28 October 2011 - 07:04 AM.
  • 11953 posts
Posted 28 October 2011 - 11:22 AM
Please contact technical support for advanced topics:http://www.smartftp....support/kb/2653
#3 eini
eini
Posted 28 October 2011 - 01:40 PM
Hi mb,
thanks for your swift reply.
... so i have to buy a product of which i'm not sure if it fulfills my requirements? :o No thanks.
I mean, the basic (i thought kind of simple) question is: why does the file-comparison (especially "file exists" check) fail, i think this is the reason for the transmissions in the first place. What does SmartFTP, what other FTP-Clients don't do?
kind regards ...
  • 11953 posts
Posted 28 October 2011 - 01:50 PM
Unfortunately we are not able to provide free technical support. Technical support will be able to assist you and that is exactly one of the selling points: we do offer professional support (experts looking at your problem, fast and guaranteed response time), that is included with the license.
Also tagged with one or more of these keywords: MLST, 550, Unicode, Schedule
