Uploads Unsuccessful - File Resets and Restarts
#1 suzzie12
suzzie12
Posted 25 March 2011 - 04:08 PM
I am trying to transfer a 195meg file. It goes to the cue and then when it hits approx 111meg...the transfer resets to 0kb and the upload starts all over again. I have been trying all morning to upload 1 file. I have searched the froum and have tries 4 or 5 things suggested to others and the solutions do not fix my problem.
Need successful help.
Here is a log capture
11:51:38] 227 Entering Passive Mode (65,18,171,159,235,178).
[11:51:38] Opening data connection to 65.18.171.159 Port: 60338
[11:51:38] STOR Hair Patterns.zip
[11:51:38] 150 Opening BINARY mode data connection for Hair Patterns.zip
[11:51:38] Socket send buffer set to 16384 bytes.
[12:00:17] 116817920 bytes transferred. (219 KB/s) (00:08:39)
[12:00:17] 451 Transfer aborted. Input/output error
[12:00:17] MDTM 20110325150543 Hair Patterns.zip
[12:00:18] 550 20110325150543 Hair Patterns.zip: No such file or directory
[12:00:18] MFMT 20110325150543 Hair Patterns.zip
[12:00:18] 500 MFMT not understood
[12:00:18] SITE UTIME Hair Patterns.zip 20110325150543 20110325150543 20110325150543 UTC
[12:00:18] 500 'SITE UTIME' not understood
[12:00:18] SITE UTIME 20110325150543 Hair Patterns.zip
[12:00:18] Transfer failed.
[12:00:18] Operation End
[12:00:18] Operation Begin
[12:00:18] Remote file exist check: "Hair Patterns.zip".
[12:00:18] SIZE Hair Patterns.zip
[12:00:18] 213 116805632
[12:00:18] MDTM Hair Patterns.zip
[12:00:18] 213 20110325120018
[12:00:18] Source File: Size=204370216, Time=2011-03-25T15:05:43
[12:00:18] Destination File: Size=116805632, Time=2011-03-25T12:00:18
[12:00:18] RecentTime=2011-03-25T16:00:17
[12:00:18] Rule "IF Destination Time=Older AND Size=Smaller AND Transfer=No Matter THEN Overwrite" matched. Action="Overwrite".
[12:00:18] PASV
[12:00:18] 227 Entering Passive Mode (65,18,171,159,235,206).
[12:00:18] Opening data connection to 65.18.171.159 Port: 60366
[12:00:18] STOR Hair Patterns.zip
[12:00:18] 150 Opening BINARY mode data connection for Hair Patterns.zip
[12:00:18] Socket send buffer set to 16384 bytes.
Edited by suzzie12, 25 March 2011 - 04:09 PM.
  • 11935 posts
Posted 25 March 2011 - 04:11 PM
The problem is that your server returns the wrong time (most likely the time on the server is not set correctly). To workaround the problem:
- Go to the menu: Favorites->Favorite Properties
- Go to the Transfer->File Exist dialog
- Change the Transfer File Exist rules to "Use Favorite's Settings"
- Click on Edit Rules
- Change the action of this rule:
To Resume instead of Overwrite
