ASCII Auto Mode
8 replies to this topic
#1 michael-jw
michael-jw
  • 9 posts
Posted 01 March 2011 - 04:35 PM
Hello,
having trouble to upload .js or .txt etc. automatically in ASCII Mode.
If i switch from AUTO to ASCII Transfer-Mode it works fine.
But not if i acitvate AUTO
My Question is:
Shouldnt smartftp upload always .js files as ASCII in automatic mode.
Or do i have to add .js and other to the ASCII List >favourite settings?
I tested this settings:
Posted Image
Result - upload still in BINARY Mode.
Version: 4.0.1169.0
Best regards
Michael
#2 michael-jw
michael-jw
  • 9 posts
Posted 01 March 2011 - 04:40 PM
Service Pack 3 (Build 2600)
CPU Speed : 3192 MHz
Total Memory : 2047 MB
Free Memory : 2047 MB
Version : 4.0.1169.0
Time Stamp : 2011-02-24 05:51:51
Maintenance : 2011-10-29
Days in use : 1303
de-DE
Version : 8.0.6001.18702
#3 mb
Posted 01 March 2011 - 04:50 PM
If SmartFTP detects that you are uploading to a server that run on the Windows operating system, then binary mode is used, regardless whether the file matches the ascii list.
Generally we do not recommend to upload any files in Ascii mode. It's a relict from the past.
#4 michael-jw
michael-jw
  • 9 posts
Posted 01 March 2011 - 05:03 PM
thanks for your answer.
i try to upload to an unix server.
and want smartftp to upload ascii using the AUTO-Mode.
result is alwas binary.
#5 michael-jw
michael-jw
  • 9 posts
Posted 01 March 2011 - 05:05 PM
[18:07:04] MLST nurjs.js
[18:07:04] 550 Can't check for file existence
[18:07:04] Dieser Vorgang wurde der Übertragungswarteschlange hinzugefügt. Der Status wird dort angezeigt.
[18:07:04] 250-Begin
[18:07:04] type=file;size=92;modify=20110301170654;UNIX.mode=0644;UNIX.uid=33;UNIX.gid=33;unique=15g3e287cb; nurjs.js
[18:07:04] 250 End.
Edited by michael-jw, 01 March 2011 - 05:07 PM.
Posted 01 March 2011 - 05:18 PM
For the trransfer log, please double click the file in the transfer queue window.
#7 michael-jw
michael-jw
  • 9 posts
Posted 02 March 2011 - 07:36 AM
[08:34:24] Initializing. Transfer Queue v4.0.1169.0.
[08:34:24] Operation Begin
[08:34:24] Ermittle IP zu Hostnamen
[08:34:24] Verbindung mit
[08:34:24] Verbunden mit
[08:34:24] 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
[08:34:24] 220-You are user number 7 of 50 allowed.
[08:34:24] 220-Local time is now 08:34. Server port: 21.
[08:34:24] 220-This is a private system - No anonymous login
[08:34:24] 220-IPv6 connections are also welcome on this server.
[08:34:24] 220 You will be disconnected after 15 minutes of inactivity.
[08:34:24] USER m5257_ftp
[08:34:24] 331 User m5257_ftp OK. Password required
[08:34:24] PASS (unsichtbar)
[08:34:24] 230-User m5257_ftp has group access to: www-data
[08:34:24] 230 OK. Current restricted directory is /
[08:34:24] SYST
[08:34:24] 215 UNIX Type: L8
[08:34:24] Erkannter Servertyp: UNIX
[08:34:24] RTT: 39.711 ms
[08:34:24] FEAT
[08:34:24] 211-Extensions supported:
[08:34:24] EPRT
[08:34:24] IDLE
[08:34:24] MDTM
[08:34:24] SIZE
[08:34:24] REST STREAM
[08:34:24] MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[08:34:24] MLSD
[08:34:24] ESTP
[08:34:24] PASV
[08:34:24] EPSV
[08:34:24] SPSV
[08:34:24] ESTA
[08:34:24] AUTH TLS
[08:34:24] PBSZ
[08:34:24] PROT
[08:34:24] 211 End.
[08:34:24] Erkannte Server-Software: PureFTPd
[08:34:24] PWD
[08:34:25] 257 "/" is your current location
[08:34:25] CWD /layout_/scripts/test
[08:34:25] 250 OK. Current directory is /scripts/test
[08:34:25] PWD
[08:34:25] 257 "scripts/test" is your current location
[08:34:25] TYPE I
[08:34:25] 200 TYPE is now 8-bit binary
[08:34:25] PASV
[08:34:25] 227 Entering Passive Mode
[08:34:25] Öffne Datenverbindung zu
[08:34:25] STOR test.js
[08:34:25] 150 Accepted data connection
[08:34:25] 4692 Byte übertragen. (99,6 KB/s) (46 ms)
[08:34:25] 226-File successfully transferred
[08:34:25] 226 0.147 seconds (measured here), 31.24 Kbytes per second
[08:34:25] MDTM 20110302072621 test.js
[08:34:25] 550 Can't check for file existence
[08:34:25] MLST test.js
[08:34:25] 250-Begin
[08:34:25] type=file;size=4692;modify=20110302073424;UNIX.mode=0644;UNIX.uid=33;UNIX.gid=33;unique=15g95163a; test.js
[08:34:25] 250 End.
[08:34:25] Source File Size=4692, Destination File Size=4692
[08:34:25] Operation End
Edited by michael-jw, 02 March 2011 - 07:37 AM.
Posted 02 March 2011 - 12:08 PM
Thank you. The next build will contain the bug fix. As a workaround for now, add the *.js filter to the ascii list in the default favorite.
#9 mb
Posted 07 March 2011 - 10:31 PM
The new version has been released: http://www.smartftp.com/download/
Please give a try.
