Transfer failed
12 replies to this topic
#1 lulu51
lulu51
  • 7 posts
Posted 01 August 2010 - 09:56 AM
Bonjour
impossible de tranferer un fichier soit du serveur soit du pc
Version : 4.0.1130.0
Time Stamp : 2010-07-28 00:44:12
[11:51:36] 215 UNIX Type: L8
[11:51:36] Type de serveur détecté: UNIX
[11:51:36] RTT: 44.191 ms
[11:51:36] FEAT
[11:51:36] 211-Extensions supported:
[11:51:36] EPRT
[11:51:36] IDLE
[11:51:36] MDTM
[11:51:36] SIZE
[11:51:36] REST STREAM
[11:51:36] MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[11:51:36] MLSD
[11:51:36] AUTH TLS
[11:51:36] PBSZ
[11:51:36] PROT
[11:51:36] ESTA
[11:51:36] PASV
[11:51:36] EPSV
[11:51:36] SPSV
[11:51:36] ESTP
[11:51:36] 211 End.
[11:51:36] Logiciel serveur détecté: PureFTPd
[11:51:36] PWD
[11:51:36] 257 "/" is your current location
[11:51:36] CWD /public_html/perso
[11:51:36] 250 OK. Current directory is /public_html/perso
[11:51:36] PWD
[11:51:36] 257 "/public_html/perso" is your current location
[11:51:36] Remote file exist check: "chemin.php".
[11:51:36] MLST chemin.php
[11:51:36] 550 Can't check for file existence
[11:51:36] Transfer failed.
[11:51:36] Operation End
[11:47:56] 230 OK. Current restricted directory is /
[11:47:56] SYST
[11:47:56] 215 UNIX Type: L8
[11:47:56] Type de serveur détecté: UNIX
[11:47:56] RTT: 45.027 ms
[11:47:56] FEAT
[11:47:57] 211-Extensions supported:
[11:47:57] EPRT
[11:47:57] IDLE
[11:47:57] MDTM
[11:47:57] SIZE
[11:47:57] REST STREAM
[11:47:57] MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[11:47:57] MLSD
[11:47:57] AUTH TLS
[11:47:57] PBSZ
[11:47:57] PROT
[11:47:57] ESTA
[11:47:57] PASV
[11:47:57] EPSV
[11:47:57] SPSV
[11:47:57] ESTP
[11:47:57] 211 End.
[11:47:57] Logiciel serveur détecté: PureFTPd
[11:47:57] PWD
[11:47:57] 257 "/" is your current location
[11:47:57] CWD /public_html/perso
[11:47:57] 250 OK. Current directory is /public_html/perso
[11:47:57] PWD
[11:47:57] 257 "/public_html/perso" is your current location
[11:47:57] TYPE A
[11:47:57] 200 TYPE is now ASCII
[11:47:57] PORT 192,168,1,4,200,199
[11:47:57] 200 PORT command successful
[11:47:57] MLSD
[11:47:57] 150 Connecting to port 51399
[11:47:57] 226-Options: -a -l
[11:47:57] 226 2 matches total
[11:47:57] 212 octets transférés. (N/A/s) (0 ms)
[11:48:28] NOOP
[11:48:28] 200 Zzz...
[11:48:58] NOOP
[11:48:58] 200 Zzz...
[11:49:29] NOOP
[11:49:29] 200 Zzz...
[11:49:59] NOOP
[11:49:59] 200 Zzz...
[11:50:30] NOOP
[11:50:30] 200 Zzz...
[11:51:00] NOOP
[11:51:00] 200 Zzz...
[11:51:31] NOOP
[11:51:31] 200 Zzz...
[11:51:35] MLST chemin.php
[11:51:35] 550 Can't check for file existence
[11:51:35] L'opération a été ajoutée à la file de transfert. Vérifiez la file de transfert pour voir son état.
[11:52:06] MLST chemin.php
[11:52:06] 550 Can't check for file existence
[11:52:36] MLST chemin.php
[11:52:36] 550 Can't check for file existence
[11:53:06] MLST chemin.php
[11:53:06] 550 Can't check for file existence
[11:53:36] MLST chemin.php
[11:53:36] 550 Can't check for file existence
[11:54:06] MLST chemin.php
[11:54:06] 550 Can't check for file existence
Posted 01 August 2010 - 11:13 AM
Please post the transfer log. To get it double click the file in the transfer queue window.
#3 lulu51
lulu51
  • 7 posts
Posted 01 August 2010 - 11:33 AM
j ai cache mes codes
[13:26:51] SmartFTP v4.0.1130.0
[13:26:51] Résolution du nom d'hôte "wwwwww"
[13:26:51] Connexion à 91.121.xxx xxxx Port: 21
[13:26:51] Connecté à xxxxx0.com.
[13:26:51] 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
[13:26:51] 220-You are user number 1 of 50 allowed.
[13:26:51] 220-Local time is now 13:26. Server port: 21.
[13:26:51] 220 You will be disconnected after 15 minutes of inactivity.
[13:26:51] USER ppcabout
[13:26:51] 331 User ppcabout OK. Password required
[13:26:51] PASS (caché)
[13:26:51] 230-User ppcabout has group access to: ppcabout
[13:26:51] 230 OK. Current restricted directory is /
[13:26:51] SYST
[13:26:51] 215 UNIX Type: L8
[13:26:51] Type de serveur détecté: UNIX
[13:26:51] RTT: 43.865 ms
[13:26:51] FEAT
[13:26:51] 211-Extensions supported:
[13:26:51] EPRT
[13:26:51] IDLE
[13:26:51] MDTM
[13:26:51] SIZE
[13:26:51] REST STREAM
[13:26:51] MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[13:26:51] MLSD
[13:26:51] AUTH TLS
[13:26:51] PBSZ
[13:26:51] PROT
[13:26:51] ESTA
[13:26:51] PASV
[13:26:51] EPSV
[13:26:51] SPSV
[13:26:51] ESTP
[13:26:51] 211 End.
[13:26:51] Logiciel serveur détecté: PureFTPd
[13:26:51] PWD
[13:26:51] 257 "/" is your current location
[13:26:51] TYPE A
[13:26:51] 200 TYPE is now ASCII
[13:26:51] PORT 192,168,1,4,204,55
[13:26:51] 200 PORT command successful
[13:26:51] MLSD
[13:26:52] 150 Connecting to port 52279
[13:26:52] 226-Options: -a -l
[13:26:52] 226 34 matches total
[13:26:52] 3854 octets transférés. (N/A/s) (0 ms)
[13:26:52] TYPE I
[13:26:52] 200 TYPE is now 8-bit binary
[13:26:52] SIZE access-logs
[13:26:52] 550 I can only retrieve regular files
[13:26:52] CWD /access-logs
[13:26:52] 250 OK. Current directory is /access-logs
[13:26:52] PWD
[13:26:52] 257 "/access-logs" is your current location
[13:26:52] CWD /
[13:26:52] PWD
[13:26:52] 257 "/" is your current location
[13:26:52] SIZE www
[13:26:52] CWD /www
[13:26:52] 250 OK. Current directory is /www
[13:26:52] PWD
[13:26:52] 257 "/www" is your current location
[13:27:05] CWD /public_html
[13:27:05] 250 OK. Current directory is /public_html
[13:27:05] PWD
[13:27:05] 257 "/public_html" is your current location
[13:27:05] TYPE A
[13:27:06] 200 TYPE is now ASCII
[13:27:06] PORT 192,168,1,4,204,56
[13:27:06] 200 PORT command successful
[13:27:06] MLSD
[13:27:06] 150 Connecting to port 52280
[13:27:06] 226-Options: -a -l
[13:27:06] 226 75 matches total
[13:27:06] 8625 octets transférés. (N/A/s) (0 ms)
[13:27:37] NOOP
[13:27:37] 200 Zzz...
[13:28:07] NOOP
[13:28:07] 200 Zzz...
[13:28:38] NOOP
[13:28:38] 200 Zzz...
[13:29:08] NOOP
[13:29:08] 200 Zzz...
[13:29:33] CWD /public_html/perso
[13:29:33] 250 OK. Current directory is /public_html/perso
[13:29:33] PWD
[13:29:33] 257 "/public_html/perso" is your current location
[13:29:33] MLST chemin.php
[13:29:33] 550 Can't check for file existence
[13:29:33] L'opération a été ajoutée à la file de transfert. Vérifiez la file de transfert pour voir son état.
[13:29:34] MLST chemin.php
[13:29:34] 550 Can't check for file existence
[13:30:04] MLST chemin.php
[13:30:04] 550 Can't check for file existence
[13:33:04] MLST chemin.php
[13:33:04] 550 Can't check for file existence
[13:33:04] Transfer failed.
[13:33:04] Operation End
[13:33:34] Operation Begin
[13:33:34] Remote file exist check: "chemin.php".
[13:33:34] MLST chemin.php
[13:33:34] 550 Can't check for file existence
[13:33:34] Transfer failed.
[13:33:34] Operation End
[13:34:04] Operation Begin
[13:34:04] Remote file exist check: "chemin.php".
[13:34:04] MLST chemin.php
[13:34:04] 550 Can't check for file existence
[13:34:04] Transfer failed.
[13:34:04] Operation End
[13:34:34] Operation Begin
[13:34:35] Remote file exist check: "chemin.php".
[13:34:35] MLST chemin.php
[13:34:35] 550 Can't check for file existence
[13:34:35] Transfer failed.
[13:34:35] Operation End
Edited by lulu51, 01 August 2010 - 11:35 AM.
#4 lulu51
lulu51
  • 7 posts
Posted 01 August 2010 - 11:44 AM
[13:29:33] Operation Begin
[13:29:33] Résolution du nom d'hôte "wwwwwwww.com"
[13:29:33] Connexion à 91.121.xxxxxx Port: 21
[13:29:33] Connecté à wwwwwww.com.
[13:29:33] 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
[13:29:33] 220-You are user number 2 of 50 allowed.
[13:29:33] 220-Local time is now 13:29. Server port: 21.
[13:29:33] 220 You will be disconnected after 15 minutes of inactivity.
[13:29:33] USER ppcabout
[13:29:33] 331 User ppcabout OK. Password required
[13:29:33] PASS (caché)
[13:29:34] 230-User ppcabout has group access to: ppcabout
[13:29:34] 230 OK. Current restricted directory is /
[13:29:34] SYST
[13:29:34] 215 UNIX Type: L8
[13:29:34] Type de serveur détecté: UNIX
[13:29:34] RTT: 43.674 ms
[13:29:34] FEAT
[13:29:34] 211-Extensions supported:
[13:29:34] EPRT
[13:29:34] IDLE
[13:29:34] MDTM
[13:29:34] SIZE
[13:29:34] REST STREAM
[13:29:34] MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[13:29:34] MLSD
[13:29:34] AUTH TLS
[13:29:34] PBSZ
[13:29:34] PROT
[13:29:34] ESTA
[13:29:34] PASV
[13:29:34] EPSV
[13:29:34] SPSV
[13:29:34] ESTP
[13:29:34] 211 End.
[13:29:34] Logiciel serveur détecté: PureFTPd
[13:29:34] PWD
[13:29:34] 257 "/" is your current location
[13:29:34] CWD /public_html/perso
[13:29:34] 250 OK. Current directory is /public_html/perso
[13:29:34] PWD
[13:29:34] 257 "/public_html/perso" is your current location
[13:29:34] Remote file exist check: "chemin.php".
[13:29:34] Transfer failed.
[13:29:34] Operation End
[13:30:04] Operation Begin
[13:30:04] Remote file exist check: "chemin.php".
[13:30:04] Transfer failed.
[13:30:04] Operation End
[13:30:34] Operation Begin
[13:30:34] Remote file exist check: "chemin.php".
[13:30:34] MLST chemin.php
[13:30:34] 550 Can't check for file existence
[13:30:34] Transfer failed.
[13:30:34] Operation End
[13:31:04] Operation Begin
[13:31:04] Remote file exist check: "chemin.php".
[13:31:04] MLST chemin.php
[13:31:04] 550 Can't check for file existence
[13:31:04] Transfer failed.
[13:31:04] Operation End
[13:31:34] Operation Begin
[13:31:34] Remote file exist check: "chemin.php".
[13:31:34] MLST chemin.php
[13:31:34] 550 Can't check for file existence
[13:31:34] Transfer failed.
[13:31:34] Operation End
[13:32:04] Operation Begin
[13:32:04] Remote file exist check: "chemin.php".
[13:32:04] MLST chemin.php
[13:32:04] 550 Can't check for file existence
[13:32:04] Transfer failed.
[13:32:04] Operation End
[13:32:34] Operation Begin
[13:32:34] Remote file exist check: "chemin.php".
[13:32:34] MLST chemin.php
[13:32:34] 550 Can't check for file existence
[13:32:34] Transfer failed.
[13:32:34] Operation End
[13:33:04] Operation Begin
[13:33:04] Remote file exist check: "chemin.php".
[13:35:05] Operation Begin
[13:35:05] Remote file exist check: "chemin.php".
[13:35:05] MLST chemin.php
[13:35:05] 550 Can't check for file existence
[13:35:05] Transfer failed.
[13:35:05] Operation End
[13:35:35] Operation Begin
[13:35:35] Remote file exist check: "chemin.php".
[13:35:35] MLST chemin.php
[13:35:35] 550 Can't check for file existence
[13:35:35] Transfer failed.
[13:35:35] Operation End
[13:36:05] Operation Begin
[13:36:05] Remote file exist check: "chemin.php".
[13:36:05] MLST chemin.php
[13:36:05] 550 Can't check for file existence
[13:36:05] Transfer failed.
[13:36:05] Operation End
[13:36:35] Operation Begin
[13:36:35] Remote file exist check: "chemin.php".
[13:36:35] MLST chemin.php
[13:36:35] 550 Can't check for file existence
[13:36:35] Transfer failed.
[13:36:35] Operation End
[13:37:05] Operation Begin
[13:37:05] Remote file exist check: "chemin.php".
[13:37:05] MLST chemin.php
[13:37:05] 550 Can't check for file existence
[13:37:05] Transfer failed.
[13:37:05] Operation End
[13:37:35] Operation Begin
[13:37:35] Remote file exist check: "chemin.php".
[13:37:35] MLST chemin.php
[13:37:35] 550 Can't check for file existence
[13:37:35] Transfer failed.
[13:37:35] Operation End
[13:38:05] Operation Begin
[13:38:05] Remote file exist check: "chemin.php".
[13:38:05] MLST chemin.php
[13:38:05] 550 Can't check for file existence
[13:38:05] Transfer failed.
[13:38:05] Operation End
[13:38:35] Operation Begin
[13:38:35] Remote file exist check: "chemin.php".
[13:38:35] MLST chemin.php
[13:38:35] 550 Can't check for file existence
[13:38:35] Transfer failed.
[13:38:35] Operation End
[13:39:05] Operation Begin
[13:39:05] Remote file exist check: "chemin.php".
[13:39:05] MLST chemin.php
[13:39:05] 550 Can't check for file existence
[13:39:05] Transfer failed.
[13:39:05] Operation End
[13:39:35] Operation Begin
[13:39:35] Remote file exist check: "chemin.php".
[13:39:35] MLST chemin.php
[13:39:35] 550 Can't check for file existence
[13:39:35] Transfer failed.
[13:39:35] Operation End
[13:40:05] Operation Begin
[13:40:05] Remote file exist check: "chemin.php".
[13:40:05] MLST chemin.php
[13:40:05] 550 Can't check for file existence
[13:40:05] Transfer failed.
[13:40:05] Operation End
[13:40:35] Operation Begin
[13:40:35] Remote file exist check: "chemin.php".
[13:40:35] MLST chemin.php
[13:40:36] 550 Can't check for file existence
[13:40:36] Transfer failed.
[13:40:36] Operation End
[13:41:06] Operation Begin
[13:41:06] Remote file exist check: "chemin.php".
[13:41:06] MLST chemin.php
[13:41:06] 550 Can't check for file existence
[13:41:06] Transfer failed.
[13:41:06] Operation End
[13:41:36] Operation Begin
[13:41:36] Remote file exist check: "chemin.php".
[13:41:36] MLST chemin.php
[13:41:36] 550 Can't check for file existence
[13:41:36] Transfer failed.
[13:41:36] Operation End
[13:42:06] Operation Begin
[13:42:06] Remote file exist check: "chemin.php".
[13:42:06] MLST chemin.php
[13:42:06] 550 Can't check for file existence
[13:42:06] Transfer failed.
[13:42:06] Operation End
[13:42:36] Operation Begin
[13:42:36] Remote file exist check: "chemin.php".
[13:42:36] MLST chemin.php
[13:42:36] 550 Can't check for file existence
[13:42:36] Transfer failed.
[13:42:36] Operation End
#5 mb
Posted 01 August 2010 - 12:08 PM
The file does not exist on the server, therefore you cannot download it. Remove all the files from the transfer queue. Then try again.
#6 lulu51
lulu51
  • 7 posts
Posted 01 August 2010 - 12:26 PM
je veux transferer le fichier de mon PC vers le serveur
le fichier existe sur le PC
#7 mb
Posted 01 August 2010 - 12:29 PM
Try it with the English version of SmartFTP: menu: Tools->Settings. Then go to the Interface->Language dialog and change the language to English. Then restart SmartFTP and try again.
#8 lulu51
lulu51
  • 7 posts
Posted 01 August 2010 - 12:34 PM
cela ne marche pas
hosting Mavenhosting > cpanel
[14:31:52] 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
[14:31:52] 220-You are user number 3 of 50 allowed.
[14:31:52] 220-Local time is now 14:32. Server port: 21.
[14:31:52] 220 You will be disconnected after 15 minutes of inactivity.
[14:31:52] USER ppcabout
[14:31:52] 331 User ppcabout OK. Password required
[14:31:52] PASS (hidden)
[14:31:54] 230-User ppcabout has group access to: ppcabout
[14:31:54] 230 OK. Current restricted directory is /
[14:31:54] SYST
[14:31:54] 215 UNIX Type: L8
[14:31:54] Detected Server Type: UNIX
[14:31:54] RTT: 44.490 ms
[14:31:54] FEAT
[14:31:54] 211-Extensions supported:
[14:31:54] EPRT
[14:31:54] IDLE
[14:31:54] MDTM
[14:31:54] SIZE
[14:31:54] REST STREAM
[14:31:54] MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[14:31:54] MLSD
[14:31:54] AUTH TLS
[14:31:54] PBSZ
[14:31:54] PROT
[14:31:54] ESTA
[14:31:54] PASV
[14:31:54] EPSV
[14:31:54] SPSV
[14:31:54] ESTP
[14:31:54] 211 End.
[14:31:54] Detected Server Software: PureFTPd
[14:31:54] PWD
[14:31:54] 257 "/" is your current location
[14:31:54] CWD /public_html/perso
[14:31:54] 250 OK. Current directory is /public_html/perso
[14:31:54] PWD
[14:31:54] 257 "/public_html/perso" is your current location
[14:31:54] Remote file exist check: "chemin.php".
[14:31:54] MLST chemin.php
[14:31:54] 550 Can't check for file existence
[14:31:54] Transfer failed.
Statut : Connecté
Statut : Démarrage de l'envoi de C:\DATA\Boutique\avoir\chemin.php
Commande : CWD /public_html/perso
Réponse : 250 OK. Current directory is /public_html/perso
Commande : PWD
Réponse : 257 "/public_html/perso" is your current location
Commande : TYPE A
Réponse : 200 TYPE is now ASCII
Commande : PASV
Réponse : 227 Entering Passive Mode (94,23,42,114,216,235)
Commande : STOR chemin.php
Réponse : 150 Accepted data connection
Réponse : 226-File successfully transferred
Réponse : 226 0.005 seconds (measured here), 6.79 Kbytes per second
Statut : Transfert de fichier réussi, transféré 39 octets en 1 seconde
Statut : Récupération du contenu du dossier...
Commande : TYPE I
Réponse : 200 TYPE is now 8-bit binary
Commande : PASV
Réponse : 227 Entering Passive Mode (94,23,42,114,145,160)
Commande : MLSD
Réponse : 226-Options: -a -l
Réponse : 226 3 matches total
Statut : Succès de la lecture du contenu du dossier
[/size]
Edited by mb, 01 August 2010 - 12:45 PM.
#9 mb
Posted 01 August 2010 - 12:46 PM
Post the system information from the menu: help->About "System Information" dialog.
#10 lulu51
lulu51
  • 7 posts
Posted 01 August 2010 - 12:53 PM
Microsoft Windows 7 Ultimate Edition
(Build 7600)
CPU Speed : 2918 MHz
Total Memory : 2047 MB
Free Memory : 1795 MB
Maintenance : 2010-10-04
Days in use : 326
en-US
Version : 8.0.7600.16385
#11 mb
Posted 01 August 2010 - 12:58 PM
Now please enable debug logging:
http://www.smartftp....logs-f2613.html
Restart SmartFTP. Try the transfer again.
Then send us (email to support@smartftp.com) all the sfTransfer*.log from the %appdata%\SmartFTP\Client 2.0 folder.
#12 lulu51
lulu51
  • 7 posts
Posted 01 August 2010 - 01:12 PM
C'est fait
Lucien
#13 mb
Posted 01 August 2010 - 04:59 PM
The problem was that the customer has enabled file encryption but set an empty password. Disabling encryption in the Transfer->Encryption dialog in the Favorite properties solved the issue.
