Icons in taskbar act strange
3 replies to this topic
#1 Monkeyman
Monkeyman
  • 22 posts
Posted 02 July 2010 - 09:09 PM
I'm not sure is this a bug or something on my side, but after upgrading to the latest version icons in taskbar started to act a bit strange, not as usual.
I have Windows 7 and SmartFTP was added permanently to taskbar, so I could access it faster. Before upgrade, when I clicked an icon it became active and remained this way until I closed the program. Now it's different: when I click SmartFTP shortcut in taskbar, a new and empty icon is being created. You may look at the picture below to get the idea:
Posted Image
Is this normal? This is definitely not the default Windows behavior.
Edited by Monkeyman, 02 July 2010 - 09:10 PM.
  • 11935 posts
Posted 02 July 2010 - 09:42 PM
I don't see this problem here. Try to uninstall SmartFTP. Then make try to install it again. Maybe this fixes the issue.
#3 Monkeyman
Monkeyman
  • 22 posts
Posted 03 July 2010 - 10:35 AM
Well, reinstalling did help, but... If there's no icon pinned to taskbar and you launch SmartFTP from Programs menu, the icon will be empty as on picture above. When you pin shortcut manually, it'll have icon.
Still not sure if this is my problem or what.
Any way to clear/rebuild icon cache and check this again?
  • 11935 posts
Posted 22 February 2011 - 02:04 PM
Did you try this?
http://www.winhelpon...-windows-vista/
