Planification tâche
7 replies to this topic
#1 mozzlo
mozzlo
  • 12 posts
Posted 16 March 2010 - 10:25 AM
Bonjour,
Avec SmartFtp edition familliale, je n'arrive pas à planifier une tache périodiquement.
SmartFtp ne s'ouvre pas tout seul.
y a t-il une astuce que je ne vois pas ?
Merci d'avance...
Edited by mozzlo, 16 March 2010 - 10:26 AM.
  • 11934 posts
Posted 16 March 2010 - 08:56 PM
You need to run it as a service: http://www.smartftp....vice-f2624.html
#3 mozzlo
mozzlo
  • 12 posts
Posted 17 March 2010 - 10:00 AM
Tks a lot, but now, i am unable to :
# In the Actions tab click on New...
# In the New Action dialog set the Action to Start a program if this is not the case yet
as an error occured saying roughtly that i haven't the right to do such action.
here the error : http://lesvieuxchene...img/Capture.JPG (sorry in french...)
I 'am the only one using the workstation as an administrator under windows 7 family premium.
Have you got any tips regarding that matter ?
tks a lot..
Edited by mozzlo, 17 March 2010 - 10:01 AM.
  • 11934 posts
Posted 18 March 2010 - 09:13 AM
Try to change the user in the first page in the create Task dialog:
Posted Image
#5 mozzlo
mozzlo
  • 12 posts
Posted 18 March 2010 - 08:02 PM
Posted Image
ok, many thanks, i 've planned a task for tomorow...
#6 mozzlo
mozzlo
  • 12 posts
Posted 20 March 2010 - 01:34 PM
Ok for the planification (task plan), it works..
Smartftp now run but the task inside sftp dooesn't run at all !
I have to do it manually...
Any idea ?
Tks
#7 mb
  • 11934 posts
Posted 20 March 2010 - 04:40 PM
Make sure that you are running SmartFTP under the correct user. I would first configure everything under the same user that you use for the task. This way you can verify that the user has the correct registry settings as well as access to the transfer queue .xml file.
You can also enable debug logging:
http://www.smartftp....logs-f2613.html
And enable the transfer logging as well. Menu: Tools->Settings. Then go to the Advanced dialog and enable the log.
#8 mozzlo
mozzlo
  • 12 posts
Posted 22 March 2010 - 06:00 PM
Ok it works now, i start all over again, it's fine. tks a lot..
