Problem with Favorites
9 replies to this topic
#1 Rob Watkins
Rob Watkins
  • 5 posts
Posted 26 November 2008 - 05:31 PM
I have recently upgraded to SmartFTP v3.0.1024.33 on Windows XP.
Previously I had a sub-folder called "My sites" under Favorites which I had pinned to the side of the program window and Auto Hidden, and I still can do this.
However now, each time I exit and start up again, the Favorites folder I've pinned to the side comes up empty, although all of my Favorites are still intact when I look at Favorites from the main menu bar.
(Hope that makes sense!)
Can anybody please help me?
Rob
Edited by Rob Watkins, 26 November 2008 - 05:47 PM.
  • 11953 posts
Posted 26 November 2008 - 05:54 PM
I think it's the same problem as here:
http://www.smartftp....tes-t15713.html
#3 Rob Watkins
Rob Watkins
  • 5 posts
Posted 26 November 2008 - 07:20 PM
I thought so too, I tried that solution and it didn't work for me I'm afraid :(
  • 11953 posts
Posted 26 November 2008 - 07:22 PM
Do you see an empty window when you go to the menu: Favorites->Edit Favorites?
#5 Rob Watkins
Rob Watkins
  • 5 posts
Posted 27 November 2008 - 09:30 AM
Exactly so; although everything is intact in the Favorites menu in the main menu bar.
  • 11953 posts
Posted 27 November 2008 - 11:46 AM
Check if you have an orphaned desktop.ini in the %AppData% folder. If yes delete it. You need to enable the [x] Show Hidden Files and Show System Files option in the Windows Explorer to see the desktop.ini
#7 Rob Watkins
Rob Watkins
  • 5 posts
Posted 27 November 2008 - 03:40 PM
Thanks very much for that, it's almost working now. I do have to have the folders list showing, otherwise my Favorites pane comes up blank, but that's close enough!
  • 11953 posts
Posted 27 November 2008 - 04:10 PM
That's a problem we will fix in a future version of SmartFTP (couple of weeks).
#9 Rob Watkins
Rob Watkins
  • 5 posts
Posted 27 November 2008 - 04:32 PM
Fabulous! I know it's not really that big an issue, but I've been using SmartFTP for a couple of years now and I've really got used to that feature.
Thanks again and I look forward to the update :(
Edited by Rob Watkins, 27 November 2008 - 04:33 PM.
#10 mb
  • 11953 posts
Posted 02 December 2008 - 11:53 PM
Hey Rob ..
The latest beta version fixes the problem with the folder pane:
http://www.smartftp....et/SFTPBeta.exe
