Remote Edit problem, Cannot use Notepad++
31 replies to this topic
#21 Andy Hopkins
Andy Hopkins
  • 16 posts
Posted 23 July 2008 - 09:42 PM
Works as expected on the test systems I tested it. You said the 2nd file doesn't open. Is the item added to the transfer queue?
Yes it is added to the transfer queue.
#22 mb
Posted 23 July 2008 - 09:44 PM
And what does its status say? And can you post the log of the item.
Are you using the default settings in Notepad++ or did you change something?
Does it happen with every file?
#23 Andy Hopkins
Andy Hopkins
  • 16 posts
Posted 23 July 2008 - 10:53 PM
I haven't made many changes to notepad++
I have attached the logs.
Log files
The transfer Q remains in monitoring.
Hope this helps,
Andy
#24 mb
Posted 23 July 2008 - 10:59 PM
Sorry I can't reproduce it and we have tested it on about 10 different systems here. Do you have another computer you can try it?
#25 Andy Hopkins
Andy Hopkins
  • 16 posts
Posted 23 July 2008 - 11:07 PM
I do have a laptop, but that's running Vista64 It works fine on there.
I will have to try to find a windows XP machine. I'll try tomorrow.
Thanks for your help so far.
Andy
#26 Andy Hopkins
Andy Hopkins
  • 16 posts
Posted 24 July 2008 - 09:08 PM
HI
Have tested smartFTP on another PC running windows XP. The only main difference between them is the my main PC, is windows XP SP3. The test PC is Windows XP SP2.
I had the same problem on the the test PC.
#27 mb
Posted 24 July 2008 - 09:13 PM
You might have the same application installed on both XP computers which causes the problem. Maybe you can create a movie of what you are doing exactly and we will something we didn't consider before. You find some screen capture applications in the readme at: http://www.smartftp....dMe-t12769.html
#28 mb
Posted 24 July 2008 - 09:40 PM
How do you use the Notepad++ editor. Did you add the file extensions to the Remote Edit settings dialog? And then do you select Notepad++ from the Edith With submenu in the context menu?
#29 Andy Hopkins
Andy Hopkins
  • 16 posts
Posted 25 July 2008 - 07:42 AM
I have notepad++ has both the default viewer, the default editor within windows for the file types as follows:
.css, .ini, .js, .log, .php, .txt, .html
In SmartFTP It's the default editor for the following:
.html, .module, .php, .tpl, .xml
so far I have tested .html, .php, .css files and I get the same problem.
Thanks again, for your time and help.
Andy
#30 Andy Hopkins
Andy Hopkins
  • 16 posts
Posted 31 July 2008 - 07:04 AM
I have downloaded the lastest build of smartftp and am still having the same problem. ? :(
#31 mb
Posted 31 July 2008 - 07:06 AM
We didn't make any changes related to this problem since we are unable to reproduce it. We have run some tests with more than 20 installations in the meanwhile. My guess is that it is related to something you have installed.
You can setup a VM using VirtualPC and then try to reproduce it there. Then you can send us the VM and we can debug the problem and tell you what causes it.
#32 Andy Hopkins
Andy Hopkins
  • 16 posts
Posted 31 July 2008 - 02:17 PM
Ok, I'll try and setup a VM system and recreate the problem. Many thanks,
