CPU Usage
24 replies to this topic
#21 mb
Posted 11 July 2008 - 08:45 AM
I did some further changes which should again lower the usage significantly:
Please try the latest version (.15) from there: http://www.smartftp.com/download
There is still one known problem I'm trying to find/fix and then the usage should be constant regardless the number of MDI children open.
#22 gwynne
gwynne
  • 3 posts
Posted 11 July 2008 - 12:46 PM
I have installed release v3...15 and can say that has really fixed it. Hardly any activity showing on the Windows Task Manager and reflected in operation of other applications.
Many thanks, job well done!!
#23 AllanMC
AllanMC
  • 7 posts
Posted 11 July 2008 - 03:37 PM
Wow, that was a huge improvement!
Now my CPU usage is only on ~0% both minimized and maximized without mousemovement. Heavy mousemovement over the SmartFTP UI controls results in 20-40% CPU usage.
Edited by AllanMC, 11 July 2008 - 03:39 PM.
#24 mb
Posted 12 July 2008 - 03:03 PM
The newest build (1020.1) reduces the CPU usage when there are many MDI windows open. You can get it from:
#25 Pjack
Pjack
  • 14 posts
Posted 18 July 2008 - 07:00 AM
I have many remote browsers too so I have at any given time 5-6 open sometimes many more. I ended up waiting instead of re-installing 2.5 again and this latest build is a huge improvement. It doesn't seem to use any CPU while idle now which is great sorta like previous vs. Still uses a good amount with mouse movement but at least its much much better while not in use.
Thanks for fixing that.
