Timeout for hash checks not set for multipart transfers
5 replies to this topic
#1 frustr8d
frustr8d
  • 18 posts
Posted 03 May 2008 - 02:01 AM
SmartFTP isn't correctly dynamically increasing the timeout when doing multipart transfers, even for files of several GB.
This is fatal when combined with the fact that multipart transfers always overwrite. The hash check times out, SmartFTP retries, then the file is started all over again from the beginning. Basically, big files will never complete and eat bandwidth forever.
So I guess this is really two bugs, since hash checks always have the possibility of timing out even when the timeout is dynamically set correctly, and would restart from the beginning regardless.
Posted 03 May 2008 - 02:16 AM
First of all multi part transfers do not always overwrite. And second the hash calculation is dynamically calculated. It assumes that the server's performance is 1 MB/s. Also there is a setting for the upper limit for the hash calculation and by default it is below 1 GB.
My recommendation: Before you post a bug report follow the instructions in the Bug Report readme. If you fail to do so we are unable to look at your bug reports.
#3 frustr8d
frustr8d
  • 18 posts
Posted 03 May 2008 - 06:38 AM
Sorry. When I say "not set" I mean it is not calculated at all. It's dynamically set to whatever the favorite is set to (default is 60s for me).
Multi part transfers always overwrite existing, completed files for me. I'm not speaking of partially downloaded files to be resumed. I mean files identical on the source and destination before creating a transfer. Actually, it seems to not exactly be overwritten destructively, but it certainly spends enough time downloading every part of it again.
After looking at this, I wonder what happens when there is a connection timeout at any other point in the transfer.
I did a small test with:
- 13.5MB zip file
- Multi part, 2 workers
- Favorite's connection timeout = 2s
Service Pack 2 (Build 2600)
CPU Speed : 2563 MHz
Total Memory : 2047 MB
Free Memory : 1061 MB
Version : 3.0.1015.5
Time Stamp : 2008-05-02 14:09:20
Unlicensed
Days in use : 387
sfFTPLib.dll : 1.5.13.17
sfFavorites.dll : 1.0.11.5
sfTransferQueue.dll : 1.0.8.5
sfFTPShellExtension.dll : 1.0.6.5
SmartFTP.exe : 3.0.1015.5
Version : 6.0.2900.2180
[01:39:28] Initializing. Transfer Queue v1.0.8.5.
[01:39:28] Resolving host name "10.10.10.10"
[01:39:28] Connecting to 10.10.10.10 Port: 21
[01:39:28] Connected to 10.10.10.10.
[01:39:28] 220 Gene6 FTP Server v3.10.0 (Build 4) ready...
[01:39:28] AUTH TLS
[01:39:28] 234 AUTH command ok; starting SSL connection.
[01:39:28] Connected. Exchanging encryption keys...
[01:39:28] Session Cipher: 128 bit RC4
[01:39:28] TLS encrypted session established.
[01:39:28] PBSZ 0
[01:39:28] 200 PBSZ=0
[01:39:28] USER ftpuser
[01:39:28] 331 Password required for ftpuser.
[01:39:28] PASS (hidden)
[01:39:28] 230 User ftpuser logged in.
[01:39:28] SYST
[01:39:28] 215 UNIX Type: L8
[01:39:28] Detected Server Type: UNIX
[01:39:28] FEAT
[01:39:28] 211-Extensions supported:
[01:39:28] AUTH TLS
[01:39:28] CCC
[01:39:28] CLNT
[01:39:28] CPSV
[01:39:28] EPRT
[01:39:28] EPSV
[01:39:28] MDTM
[01:39:28] MFCT
[01:39:28] MFMT
[01:39:28] MLST type*;size*;create;modify*;
[01:39:28] MODE Z
[01:39:28] PASV
[01:39:28] PBSZ
[01:39:28] PROT
[01:39:28] REST STREAM
[01:39:28] SIZE
[01:39:28] SSCN
[01:39:28] TVFS
[01:39:28] UTF8
[01:39:28] XCRC "filename" SP EP
[01:39:28] XMD5 "filename" SP EP
[01:39:28] XSHA1 "filename" SP EP
[01:39:28] 211 End.
[01:39:28] CLNT SmartFTP 3.0.1015.5
[01:39:28] 200 Noted.
[01:39:28] Detected Server Software: Gene6 FTP Server 3.x
[01:39:28] OPTS UTF8 ON
[01:39:28] 200 UTF8 OPTS ON
[01:39:28] PWD
[01:39:29] 257 "/" is current directory.
[01:39:29] CWD /testdir
[01:39:29] 250 CWD command successful. "/testdir" is current directory.
[01:39:29] PWD
[01:39:29] 257 "/testdir" is current directory.
[01:39:29] MLST test file.zip
[01:39:29] 250-Begin
[01:39:29] type=file;size=13822132;modify=20080422051411; /testdir/test file.zip
[01:39:29] 250 End.
[01:39:29] Multipart Transfer. Number of Workers = 2
[01:39:29] Resolving host name "10.10.10.10"
[01:39:29] Connecting to 10.10.10.10 Port: 21
[01:39:29] Connected to 10.10.10.10.
[01:39:29] 220 Gene6 FTP Server v3.10.0 (Build 4) ready...
[01:39:29] AUTH TLS
[01:39:29] AUTH TLS
[01:39:29] 234 AUTH command ok; starting SSL connection.
[01:39:29] Connected. Exchanging encryption keys...
[01:39:29] Session Cipher: 128 bit RC4
[01:39:29] TLS encrypted session established.
[01:39:29] PBSZ 0
[01:39:29] PBSZ 0
[01:39:29] 200 PBSZ=0
[01:39:29] USER ftpuser
[01:39:29] 331 Password required for ftpuser.
[01:39:29] PASS (hidden)
[01:39:29] 230 User ftpuser logged in.
[01:39:29] SYST
[01:39:29] SYST
[01:39:29] 215 UNIX Type: L8
[01:39:29] Detected Server Type: UNIX
[01:39:29] FEAT
[01:39:29] FEAT
[01:39:29] 211-Extensions supported:
[01:39:29] AUTH TLS
[01:39:29] CCC
[01:39:29] CLNT
[01:39:29] CPSV
[01:39:29] AUTH TLS
[01:39:29] EPRT
[01:39:29] CCC
[01:39:29] EPSV
[01:39:29] CLNT
[01:39:29] MDTM
[01:39:29] CPSV
[01:39:29] MFCT
[01:39:29] EPRT
[01:39:29] MFMT
[01:39:29] EPSV
[01:39:29] MLST type*;size*;create;modify*;
[01:39:29] MDTM
[01:39:29] MODE Z
[01:39:29] MFCT
[01:39:29] PASV
[01:39:29] MFMT
[01:39:29] PBSZ
[01:39:29] PROT
[01:39:29] MODE Z
[01:39:29] REST STREAM
[01:39:30] PASV
[01:39:30] SIZE
[01:39:30] PBSZ
[01:39:30] SSCN
[01:39:30] PROT
[01:39:30] TVFS
[01:39:30] REST STREAM
[01:39:30] UTF8
[01:39:30] SIZE
[01:39:30] XCRC "filename" SP EP
[01:39:30] SSCN
[01:39:30] XMD5 "filename" SP EP
[01:39:30] TVFS
[01:39:30] XSHA1 "filename" SP EP
[01:39:30] UTF8
[01:39:30] 211 End.
[01:39:30] CLNT SmartFTP 3.0.1015.5
[01:39:30] 211 End.
[01:39:30] 200 Noted.
[01:39:30] Detected Server Software: Gene6 FTP Server 3.x
[01:39:30] OPTS UTF8 ON
[01:39:30] 200 UTF8 OPTS ON
[01:39:30] PWD
[01:39:30] PWD
[01:39:30] 257 "/" is current directory.
[01:39:30] CWD /testdir
[01:39:30] 250 CWD command successful. "/testdir" is current directory.
[01:39:30] PWD
[01:39:30] PWD
[01:39:30] 257 "/testdir" is current directory.
[01:39:30] Compression disabled. File "test file.zip" matches exception "*.zip".
[01:39:30] TYPE I
[01:39:30] TYPE I
[01:39:30] 200 Type set to I.
[01:39:30] PROT P
[01:39:30] PROT P
[01:39:30] 200 PROT command successful.
[01:39:30] PASV
[01:39:30] PASV
[01:39:30] 227 Entering Passive Mode (10,10,10,10,117,92)
[01:39:30] Opening data connection to 10.10.10.10 Port: 30044
[01:39:30] RETR test file.zip
[01:39:30] 227 Entering Passive Mode (10,10,10,10,117,85)
[01:39:30] Opening data connection to 10.10.10.10 Port: 30037
[01:39:30] Connected. Exchanging encryption keys...
[01:39:30] REST 6911066
[01:39:30] 150 Data connection accepted from 20.20.20.20:2252; transfer starting for /testdir/test file.zip (13822132 bytes)
[01:39:30] 350 Restarting at 6911066. Send STORE or RETRIEVE.
[01:39:30] Session Cipher: 128 bit RC4
[01:39:30] TLS encrypted session established.
[01:39:30] 150 Data connection accepted from 20.20.20.20:2253; transfer starting for /testdir/test file.zip (13822132 bytes)
[01:39:52] 6911066 bytes transferred. (313 KB/s) (00:00:21)
[01:39:52] 226 File sent ok.
[01:39:52] Compression disabled. File "test file.zip" matches exception "*.zip".
[01:39:52] PASV
[01:39:52] 227 Entering Passive Mode (10,10,10,10,117,88)
[01:39:52] Opening data connection to 10.10.10.10 Port: 30040
[01:39:52] REST 6773293
[01:39:52] Connected. Exchanging encryption keys...
[01:39:52] 350 Restarting at 6773293. Send STORE or RETRIEVE.
[01:39:52] RETR test file.zip
[01:39:52] 150 Data connection accepted from 20.20.20.20:2256; transfer starting for /testdir/test file.zip (13822132 bytes)
[01:39:52] Session Cipher: 128 bit RC4
[01:39:52] TLS encrypted session established.
[01:39:53] ABOR
[01:39:53] ABOR
[01:39:53] 13822132 bytes transferred. (550 KB/s) (00:00:24)
[01:39:53] MDTM test file.zip
[01:39:53] 213 20080422051411
Here the timeout should be set to 13s:
[01:39:53] Timeout dynamically set to 2s
[01:39:53] XSHA1 "test file.zip"
[01:39:55] Timeout (2s).
[01:39:55] Active Help: http://www.smartftp.com/support/kb/74
[01:39:55] Client closed the connection.
Transfer restarts completely:
[01:39:55] Initializing. Transfer Queue v1.0.8.5.
[01:39:55] Resolving host name "10.10.10.10"
[01:39:55] Connecting to 10.10.10.10 Port: 21
[01:39:55] Connected to 10.10.10.10.
[01:39:55] 220 Gene6 FTP Server v3.10.0 (Build 4) ready...
[01:39:55] AUTH TLS
[01:39:55] 234 AUTH command ok; starting SSL connection.
[01:39:55] Connected. Exchanging encryption keys...
[01:39:55] Session Cipher: 128 bit RC4
[01:39:55] TLS encrypted session established.
[01:39:55] PBSZ 0
[01:39:55] 200 PBSZ=0
[01:39:55] USER ftpuser
[01:39:55] 331 Password required for ftpuser.
[01:39:55] PASS (hidden)
[01:39:55] 230 User ftpuser logged in.
[01:39:55] SYST
[01:39:55] 215 UNIX Type: L8
[01:39:55] Detected Server Type: UNIX
[01:39:55] FEAT
[01:39:55] 211-Extensions supported:
[01:39:55] AUTH TLS
[01:39:55] CCC
[01:39:55] CLNT
[01:39:55] CPSV
[01:39:55] EPRT
[01:39:55] EPSV
[01:39:55] MDTM
[01:39:55] MFCT
[01:39:55] MFMT
[01:39:55] MLST type*;size*;create;modify*;
[01:39:55] MODE Z
[01:39:55] PASV
[01:39:55] PBSZ
[01:39:55] PROT
[01:39:55] REST STREAM
[01:39:55] SIZE
[01:39:55] SSCN
[01:39:55] TVFS
[01:39:55] UTF8
[01:39:55] XCRC "filename" SP EP
[01:39:55] XMD5 "filename" SP EP
[01:39:55] XSHA1 "filename" SP EP
[01:39:55] 211 End.
[01:39:55] CLNT SmartFTP 3.0.1015.5
[01:39:55] 200 Noted.
[01:39:55] Detected Server Software: Gene6 FTP Server 3.x
[01:39:55] OPTS UTF8 ON
[01:39:56] 200 UTF8 OPTS ON
[01:39:56] PWD
[01:39:56] 257 "/" is current directory.
[01:39:56] CWD /testdir
[01:39:56] 250 CWD command successful. "/testdir" is current directory.
[01:39:56] PWD
[01:39:56] 257 "/testdir" is current directory.
[01:39:56] MLST test file.zip
[01:39:56] 250-Begin
[01:39:56] type=file;size=13822132;modify=20080422051411; /testdir/test file.zip
[01:39:56] 250 End.
[01:39:56] Multipart Transfer. Number of Workers = 2
[01:39:56] Resolving host name "10.10.10.10"
[01:39:56] Connecting to 10.10.10.10 Port: 21
[01:39:56] Connected to 10.10.10.10.
[01:39:56] 220 Gene6 FTP Server v3.10.0 (Build 4) ready...
[01:39:56] AUTH TLS
[01:39:56] AUTH TLS
[01:39:56] 234 AUTH command ok; starting SSL connection.
[01:39:56] Connected. Exchanging encryption keys...
[01:39:56] Session Cipher: 128 bit RC4
[01:39:56] TLS encrypted session established.
[01:39:56] PBSZ 0
[01:39:56] PBSZ 0
[01:39:56] 200 PBSZ=0
[01:39:56] USER ftpuser
[01:39:56] 331 Password required for ftpuser.
[01:39:56] PASS (hidden)
[01:39:56] 230 User ftpuser logged in.
[01:39:56] SYST
[01:39:56] SYST
[01:39:56] 215 UNIX Type: L8
[01:39:56] Detected Server Type: UNIX
[01:39:56] FEAT
[01:39:56] FEAT
[01:39:56] 211-Extensions supported:
[01:39:56] AUTH TLS
[01:39:56] CCC
[01:39:56] CLNT
[01:39:56] CPSV
[01:39:56] EPRT
[01:39:56] AUTH TLS
[01:39:56] EPSV
[01:39:56] CCC
[01:39:56] MDTM
[01:39:56] CLNT
[01:39:56] MFCT
[01:39:56] CPSV
[01:39:57] MFMT
[01:39:57] EPRT
[01:39:57] MLST type*;size*;create;modify*;
[01:39:57] EPSV
[01:39:57] MODE Z
[01:39:57] MDTM
[01:39:57] PASV
[01:39:57] MFCT
[01:39:57] PBSZ
[01:39:57] MFMT
[01:39:57] PROT
[01:39:57] REST STREAM
[01:39:57] MODE Z
[01:39:57] SIZE
[01:39:57] PASV
[01:39:57] SSCN
[01:39:57] PBSZ
[01:39:57] TVFS
[01:39:57] PROT
[01:39:57] UTF8
[01:39:57] XCRC "filename" SP EP
[01:39:57] SIZE
[01:39:57] XMD5 "filename" SP EP
[01:39:57] SSCN
[01:39:57] XSHA1 "filename" SP EP
[01:39:57] TVFS
[01:39:57] 211 End.
[01:39:57] UTF8
[01:39:57] CLNT SmartFTP 3.0.1015.5
[01:39:57] 211 End.
[01:39:57] 200 Noted.
[01:39:57] Detected Server Software: Gene6 FTP Server 3.x
[01:39:57] OPTS UTF8 ON
[01:39:57] 200 UTF8 OPTS ON
[01:39:57] PWD
[01:39:57] PWD
[01:39:57] 257 "/" is current directory.
[01:39:57] CWD /testdir
[01:39:57] 250 CWD command successful. "/testdir" is current directory.
[01:39:57] PWD
[01:39:57] PWD
[01:39:57] 257 "/testdir" is current directory.
[01:39:57] Compression disabled. File "test file.zip" matches exception "*.zip".
[01:39:57] TYPE I
[01:39:57] TYPE I
[01:39:57] 200 Type set to I.
[01:39:57] PROT P
[01:39:57] PROT P
[01:39:57] 200 PROT command successful.
[01:39:57] PASV
[01:39:57] PASV
[01:39:57] 227 Entering Passive Mode (10,10,10,10,117,82)
[01:39:57] Opening data connection to 10.10.10.10 Port: 30034
[01:39:57] REST 6911066
[01:39:57] 227 Entering Passive Mode (10,10,10,10,117,93)
[01:39:57] Opening data connection to 10.10.10.10 Port: 30045
[01:39:57] RETR test file.zip
[01:39:57] Connected. Exchanging encryption keys...
[01:39:57] 350 Restarting at 6911066. Send STORE or RETRIEVE.
[01:39:58] 150 Data connection accepted from 20.20.20.20:2261; transfer starting for /testdir/test file.zip (13822132 bytes)
[01:39:58] Session Cipher: 128 bit RC4
[01:39:58] TLS encrypted session established.
[01:39:58] 150 Data connection accepted from 20.20.20.20:2260; transfer starting for /testdir/test file.zip (13822132 bytes)
Time passes here while it re-downloads the whole file.
[01:40:14] ABOR
[01:40:14] Resolving host name "10.10.10.10"
[01:40:14] Connecting to 10.10.10.10 Port: 21
[01:40:14] Connected to 10.10.10.10.
[01:40:14] 220 Gene6 FTP Server v3.10.0 (Build 4) ready...
[01:40:14] AUTH TLS
[01:40:14] 234 AUTH command ok; starting SSL connection.
[01:40:14] Connected. Exchanging encryption keys...
[01:40:14] Session Cipher: 128 bit RC4
[01:40:14] TLS encrypted session established.
[01:40:14] PBSZ 0
[01:40:14] 200 PBSZ=0
[01:40:14] USER ftpuser
[01:40:15] 331 Password required for ftpuser.
[01:40:15] PASS (hidden)
[01:40:15] 230 User ftpuser logged in.
[01:40:15] SYST
[01:40:15] 215 UNIX Type: L8
[01:40:15] Detected Server Type: UNIX
[01:40:15] FEAT
[01:40:15] 211-Extensions supported:
[01:40:15] AUTH TLS
[01:40:15] CCC
[01:40:15] CLNT
[01:40:15] CPSV
[01:40:15] EPRT
[01:40:15] EPSV
[01:40:15] MDTM
[01:40:15] MFCT
[01:40:15] MFMT
[01:40:15] MLST type*;size*;create;modify*;
[01:40:15] MODE Z
[01:40:15] PASV
[01:40:15] PBSZ
[01:40:15] PROT
[01:40:15] REST STREAM
[01:40:15] SIZE
[01:40:15] SSCN
[01:40:15] TVFS
[01:40:15] UTF8
[01:40:15] XCRC "filename" SP EP
[01:40:15] XMD5 "filename" SP EP
[01:40:15] XSHA1 "filename" SP EP
[01:40:15] 211 End.
[01:40:15] CLNT SmartFTP 3.0.1015.5
[01:40:15] 200 Noted.
[01:40:15] Detected Server Software: Gene6 FTP Server 3.x
[01:40:15] OPTS UTF8 ON
[01:40:15] 200 UTF8 OPTS ON
[01:40:15] PWD
[01:40:15] 257 "/" is current directory.
[01:40:15] CWD /testdir
[01:40:15] 250 CWD command successful. "/testdir" is current directory.
[01:40:15] PWD
[01:40:15] 257 "/testdir" is current directory.
[01:40:15] Compression disabled. File "test file.zip" matches exception "*.zip".
[01:40:15] TYPE I
[01:40:15] 200 Type set to I.
[01:40:15] PROT P
[01:40:15] 200 PROT command successful.
[01:40:15] PASV
[01:40:15] ABOR
[01:40:15] 227 Entering Passive Mode (10,10,10,10,117,86)
[01:40:15] Opening data connection to 10.10.10.10 Port: 30038
[01:40:15] REST 13192839
[01:40:15] Connected. Exchanging encryption keys...
[01:40:15] 350 Restarting at 13192839. Send STORE or RETRIEVE.
[01:40:15] RETR test file.zip
[01:40:16] 150 Data connection accepted from 20.20.20.20:2264; transfer starting for /testdir/test file.zip (13822132 bytes)
[01:40:16] Session Cipher: 128 bit RC4
[01:40:16] TLS encrypted session established.
[01:40:17] 629293 bytes transferred. (367 KB/s) (00:00:01)
[01:40:17] 226 File sent ok.
[01:40:17] 13822132 bytes transferred. (627 KB/s) (00:00:21)
[01:40:17] MDTM test file.zip
[01:40:17] 213 20080422051411
[01:40:17] Timeout dynamically set to 2s
[01:40:17] XSHA1 "test file.zip"
[01:40:19] Timeout (2s).
[01:40:19] Active Help: http://www.smartftp.com/support/kb/74
[01:40:19] Client closed the connection.
Restarts again:
[01:40:19] Initializing. Transfer Queue v1.0.8.5.
*snipped*
Posted 03 May 2008 - 06:54 AM
I see the problems. The logs help tremendously to understand them. You can expect a fix with the next 1-2 days.
#5 frustr8d
frustr8d
  • 18 posts
Posted 03 May 2008 - 07:12 AM
Wow. Mat, man, do you ever sleep? ;) Thanks, and sorry for being lazy the first time around.
Posted 06 May 2008 - 12:33 AM
The bug with the dynamic timeout has been fixed in the latest version
Can you give it a try?
But resume doesn't work yet.
