Disable Auto Connect?
4 replies to this topic
#1 chrusion
chrusion
  • 12 posts
Posted 19 April 2008 - 03:06 AM
I've looked thru all the options in Tools->Settings and Favorite Properties and cannot find anything that disables auto-connect to any and all remote servers upon start up of SmartFTP (build 1013). The only options in Tools->Settings->Interface->Workspace->Restore on start are Nothing/Everything/Remote/Local. I've tried them all and like the default of Everything because it maintains my custom pane/window layout (single local pane left, 1 - 3 remote tabs in right pane). HOWEVER, on startup I want to MANUALLY connect to a desired remote site, not have SFTP connect to EVERY SINGLE ONE of them at the SAME TIME!!
What to do?
  • 11973 posts
Posted 19 April 2008 - 03:29 AM
Go to the menu: Tools->Settings. Then in the Cache dialog set the cache to expire after 3 days. This way the Remote Browsers will use the cache instead of connecting to the server to get the new listing.
#3 chrusion
chrusion
  • 12 posts
Posted 19 April 2008 - 11:38 AM
Thanks. Works, but sure is a hidden feature if ever I saw one. Would be great to add that radio button as a check box to the Connect root and label it "Disable auto connect on startup" which would then 'activate' the duplicate option in the Cache settings (cache expiration: after X days).
And why does auto connect still function when Cache is disabled (unchecked)?
#4 Trebor808
Trebor808
Posted 20 April 2008 - 10:54 AM
This was just the question I was going to ask. It is annoying that every time you start SmartFTP, it auto logs on. Perhaps in a future version release the developers can put an option that is easier to understand.
Robert
#5 ivan.d
ivan.d
  • 8 posts
Posted 21 October 2013 - 06:37 PM
I've wanted a toggle switch for this too... the closest I've been able to come up with is the disable internet switch on the side of my laptop.
