Can't rename remote files
4 replies to this topic
#1 Jordan Bradford
Jordan Bradford
  • 6 posts
Posted 09 April 2008 - 07:09 PM
Build 3.0.1012.0
Windows 2000 SP4
I used to be able to rename remote files/folders using the right-click context menu or by selecting the file/folder and pressing F2. In SmartFTP 3 this no longer works -- the file loses its blue background highlight but retains a dotted outline; it does not enter the filename edit mode.
My cumbersome workaround is to rename files locally, upload them, and then delete the original on the remote server. If I want to create a new file or folder on the remote server, I have to create it locally first, rename it locally, and then transfer it.
Posted 09 April 2008 - 07:12 PM
We will look into it. But please install the latest version from:
#3 Jordan Bradford
Jordan Bradford
  • 6 posts
Posted 09 April 2008 - 07:32 PM
Thanks for the link.
The bug is present in 3.0.1012.15, too.
Posted 09 April 2008 - 09:56 PM
Bug fixed in the latest version (.16):
#5 Jordan Bradford
Jordan Bradford
  • 6 posts
Posted 21 April 2008 - 03:18 PM
Thanks!
