Remote/Local Browser Transfer not working correctly
3 replies to this topic
#1 jwciii
jwciii
Posted 08 April 2008 - 11:18 PM
SmartFTP 3.0.1012.13 not working correctly. When transferring to the Mainframe within an HFS segment, the type settings (e.g. Auto,Ascii,Binary) do not function correctly. In older versions of SmartFTP (e.g. 2.5) one could select ASCII mode and transfer a file between a Windows Machine and the Mainframe without a problem. This option would convert the file between EBCDIC and ASCII correctly. Now, I can transfer to Windows (local browser) fine. EBCDIC will be converted to ASCII. However, when tranferring to Mainframe (OS/390 within remote browser) it always transfers with type I. Therefore, ASCII is always sent and never converted to EBCDIC. Moreover, the BINARY mode sometimes converts between EBCDIC and ASCII. It should NEVER convert the file.
Edited by jwciii, 08 April 2008 - 11:19 PM.
  • 11953 posts
Posted 08 April 2008 - 11:47 PM
Working on the bug fix.
#3 mb
  • 11953 posts
Posted 09 April 2008 - 03:26 AM
Please try it again with the latest version. The bug has been fixed:
#4 jwciii
jwciii
Posted 09 April 2008 - 11:55 AM
Mat,
Thank you. I have downloaded the latest version and this appears to have fixed the bug. Kudos to you and your team for the fast turnaround.
