[11:44:54] 500 I won't open a connection to 192.168.27.58 (only to 123.123.123.123)
2 replies to this topic
#1 wainwra
wainwra
Posted 04 April 2008 - 09:51 AM
I'm getting this error when I tried to download a file:
This sounds like a NATting issue. The help files tell me:
Port IP Mode > IP Repeater
When the "Port IP Mode" setting is set to "Auto", the IP Repeater is enabled.
This feature will attempt to assign the correct IP address for the PORT command using an https (port 443) connection to repeater.smartftp.com to get the external IP.
This feature should only be enabled if the NAT router does not replace the internal IP in the PORT command with the external IP. This is usually the case when the connection is made to a port different than standard FTP port (21).
Unfortunately, I can't find where this setting is made. Can someone please give me a pointer?
I'm running version 3.0.1012.0
  • 11954 posts
Posted 04 April 2008 - 09:58 AM
It means FXP is disabled on this server for security reasons.
#3 wainwra
wainwra
Posted 04 April 2008 - 12:40 PM
That's odd. FXP is for server-to-server transfers, isn't it? All I'm trying to do is download something (server-client)
Can you tell me how to disable FXP?
