Remote Edit problem
3 replies to this topic
#1 neg4
neg4
Posted 02 April 2008 - 05:50 PM
For version 3.0.1012.5 and the version prior to that, I'm having a problem when trying to remote edit files. If I select Edit With: Microsoft Visual Studio 2005 or Visual Web Developer 2008,
A) the file is transferred to the local temp dir,
B) an entry is added in the Transfer Queue with status = Monitoring,
C) the specified application is started, but ...
D) there is no file open.
It does work if I just do View With these editors (i.e., the application does open with a local copy of the specified file; no Transfer Queue entry is added).
If I use notepad or WordPad for View With or Edit With, it also works as expected.
I've checked permissions on the directories, but couldn't think of any other resaons why Viewing works and Editing doesn't with the two apps I want to use.
Any help would be appreciated.
My machine info is as follows:
Microsoft Windows Server 2003 Enterprise Edition
Service Pack 2 (Build 3790)
CPU Speed : 3000 MHz
Total Memory : 2047 MB
Free Memory : 1907 MB
Version : 3.0.1012.5
Time Stamp : 2008-04-01 23:35:55
Unlicensed
Days in use : 250
sfFTPLib.dll : 1.5.12.38
sfFavorites.dll : 1.0.8.5
sfTransferQueue.dll : 1.0.5.5
sfFTPShellExtension.dll : 1.0.3.5
SmartFTP.exe : 3.0.1012.5
Version : 7.0.5730.11
Another machine experiencing the same problem is running the previous version of SmartFTP (from SFTPMSI.EXE as of Apr 1, 2008) and Windows Vista Business.
Edited by neg4, 02 April 2008 - 05:51 PM.
  • 11953 posts
Posted 03 April 2008 - 05:58 AM
Please try the latest version:
The problem should be fixed now. Thank you for reporting.
#3 neg4
neg4
Posted 03 April 2008 - 06:36 PM
As my original message states, I already tried that version (SFTPMSI.EXE from April 1st) and the version after that (SFTPNSI.EXE from April 2); the problem is not fixed with either version.
  • 11953 posts
Posted 04 April 2008 - 04:58 AM
Please try it with the new version as instructed.
