Folders Pane doesn't refresh
#1 MilitantHippy
MilitantHippy
Posted 23 March 2008 - 11:04 AM
The Folders pane does not refresh after you delete folders from the right hand pane.
I also connected to the same server but with a different login, and the folders pane simply remembered what was there from the previous login and did not update (note that I had both connections open simultaneously).
  • 11935 posts
Posted 23 March 2008 - 11:07 AM
Please try again with the latest version:
If the problem persits please provide the logs, the system information, a screenshot and a detailed description on how to reproduce it.
