Error en conexion
2 replies to this topic
#1 jcompeanmx
jcompeanmx
  • 3 posts
Posted 10 October 2007 - 12:09 AM
Acaban de actualizar el servidor donde me dan el hospedaje y desde ese momento no he podido entrar, me dicen que es un problema del smartFTP, y que tengo que cambiar de programa.
Es verdad esto, o como puedo solucionarlo
Gracias
SmartFTP v2.5.1006.48
[18:58:47] Resolviendo nombre de host "iscmx.com"
[18:58:47] Conectando a 66.7.194.207 Puerto: 21
[18:58:47] Conectado a iscmx.com.
[18:58:48] 220---------- Welcome to Pure-FTPd [TLS] ----------
[18:58:48] 220-You are user number 3 of 50 allowed.
[18:58:48] 220-Local time is now 19:59. Server port: 21.
[18:58:48] 220-IPv6 connections are also welcome on this server.
[18:58:48] 220 You will be disconnected after 15 minutes of inactivity.
[18:58:48] USER iscmx
[18:58:48] 331 User iscmx OK. Password required
[18:58:48] PASS (oculto)
[18:58:48] 230-User iscmx has group access to: iscmx
[18:58:48] 230 OK. Current restricted directory is /
[18:58:48] SYST
[18:58:48] 215 UNIX Type: L8
[18:58:48] Tipo de Servidor Detectado: UNIX
[18:58:48] FEAT
[18:58:49] 211-Extensions supported:
[18:58:49] EPRT
[18:58:49] IDLE
[18:58:49] MDTM
[18:58:49] SIZE
[18:58:49] REST STREAM
[18:58:49] MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[18:58:49] MLSD
[18:58:49] ESTP
[18:58:49] PASV
[18:58:49] EPSV
[18:58:49] SPSV
[18:58:49] ESTA
[18:58:49] AUTH TLS
[18:58:49] PBSZ
[18:58:49] PROT
[18:58:49] 211 End.
[18:58:49] Software de servidor detectado: PureFTPd
[18:58:49] PWD
[18:58:49] 257 "/" is your current location
[18:58:49] CWD /public_html/prueba
[18:58:49] 250 OK. Current directory is /public_html/prueba
[18:58:49] PWD
[18:58:49] 257 "/public_html/prueba" is your current location
[18:58:49] TYPE A
[18:58:49] 200 TYPE is now ASCII
[18:58:49] PASV
[18:58:49] 227 Entering Passive Mode (66,7,194,207,155,111)
[18:58:49] Abriendo conexión de datos 66.7.194.207 Puerto: 39791
[18:58:49] MLSD
[18:58:50] 150 Accepted data connection
[18:58:50] 447 bytes transferidos. (3.09 KB/s) (141 ms)
[18:58:50] 226-Options: -a -l
[18:58:50] 226 4 matches total
[18:59:20] NOOP
[18:59:20] 200 Zzz...
[18:59:46] CWD /public_html
[18:59:47] 250 OK. Current directory is /public_html
[18:59:47] PWD
[18:59:47] 257 "/public_html" is your current location
[18:59:47] PASV
[18:59:47] 227 Entering Passive Mode (66,7,194,207,184,209)
[18:59:47] Abriendo conexión de datos 66.7.194.207 Puerto: 47313
[18:59:47] MLSD
[18:59:47] 150 Accepted data connection
[18:59:47] 226-Options: -a -l
[18:59:47] 226 33 matches total
[18:59:47] 3763 bytes transferidos. (23.5 KB/s) (156 ms)
[18:59:50] CWD /public_html/francisco
[18:59:50] 250 OK. Current directory is /public_html/francisco
[18:59:50] PWD
[18:59:50] 257 "/public_html/francisco" is your current location
[18:59:50] PASV
[18:59:50] 227 Entering Passive Mode (66,7,194,207,237,198)
[18:59:50] Abriendo conexión de datos 66.7.194.207 Puerto: 60870
[18:59:50] MLSD
[19:00:11] Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder.
#2 Aokromes
Aokromes
    Entity From Outer Space
  • 1519 posts
Posted 11 October 2007 - 07:17 AM
Hola, prueba a cambiar de modo pasivo a activo, o a desactivar MLSD en las opciones del favorito, si no te funciona tal vez me podrias dejar una cuenta de prueba para mirartelo y decirte como arreglarlo.
#3 jcompeanmx
jcompeanmx
  • 3 posts
Posted 12 October 2007 - 05:01 AM
Muchas gracias por tu ayuda, deja intento lo que me dices y si no me da resultado te habilito una cuenta para que la pruebes.
Saludos
Jorge
