SSL/TLS internal error (Error = 0x67179ca)
3 replies to this topic
#1 2BrightSparks
2BrightSparks
  • 44 posts
Posted 18 January 2007 - 03:03 AM
Hi, we're having problems connecting to a Gene6 FTP server using TLS:
Connected to 12.215.39.118.
220 Gene6 FTP Server v3.8.0 (Build 34) ready...
AUTH TLS
234 AUTH command ok; starting SSL connection.
SSL/TLS internal error (Error = 0x67179ca).
The credentials supplied to the package were not recognized
Using V1.5.9.0 of the FTP library on Windows 2003 SP1
Any ideas?
  • 11934 posts
Posted 18 January 2007 - 03:56 AM
Some things you may want to try:
1. Make sure that you have a client cert set (ClientCert property) or in SmartFTP under the Settings -> Connection -> SSL
2. Try with other FTP clients to see if you have the same problem
#3 2BrightSparks
2BrightSparks
  • 44 posts
Posted 18 January 2007 - 04:03 AM
1. Make sure that you have a client cert set (ClientCert property) or in SmartFTP under the Settings -> SSL
Hi, 1. we don't use the ClientCert property, is it required? 2. I'll get the client to try and report back. Thanks
  • 11934 posts
Posted 18 January 2007 - 04:11 AM
1. Depends on the server of course. But I stronly recommend to use one as some servers request a client cert but they usually don't verify it.
