AUTH SSL option problem
5 replies to this topic
#1 jlcfly
jlcfly
  • 3 posts
Posted 11 July 2006 - 09:27 PM
I've set my favorite to use AUTH SSL, but when connecting, AUTH TLS is sent everytime. I've set the setting in the favorite and as the global SSL setting. I'm using 2.0.996.
  • 11952 posts
Posted 11 July 2006 - 09:48 PM
SmartFTP sends AUTH TLS command, if it fails it will fall back to the deprecated AUTH SSL. This is by design and shouldn't make any problems with your FTP server.
Please send the log.
#3 jlcfly
jlcfly
  • 3 posts
Posted 12 July 2006 - 03:26 PM
Here's the log. The problem is when the LIST command is issued, it fails. The server I'm connecting to requires AUTH SSL. I have another FTP program that issues AUTH SSL and it works just fine. It doesn't make sense to me to have an option to use AUTH SSL and then the program overrides me and issues AUTH TLS. Why have an option?
[08:22:31] SmartFTP v2.0.996.40
[08:22:31] Resolving host name "12.42.46.196"
[08:22:31] Connecting to 12.42.46.196 Port: 21
[08:22:31] Connected to 12.42.46.196.
[08:22:31] 220 hshhp-ts1 X2 WS_FTP Server 5.0.4 (1412046931)
[08:22:31] AUTH TLS
[08:22:32] 234 SSL enabled and waiting for negotiation
[08:22:32] Connected. Exchanging encryption keys...
[08:22:32] Session Cipher: 128 bit RC4
[08:22:32] TLS encrypted session established.
[08:22:32] PBSZ 0
[08:22:33] 200 PBSZ=0
[08:22:33] USER freeclear
[08:22:33] 331 Password required
[08:22:33] PASS (hidden)
[08:22:33] 230 user logged in
[08:22:33] SYST
[08:22:33] 215 UNIX
[08:22:33] TYPE I
[08:22:33] 200 Type set to IMAGE.
[08:22:33] REST 0
[08:22:33] 350 setting restart marker to 0
[08:22:33] PWD
[08:22:33] 257 "/freeclear" is current directory
[08:22:33] TYPE A
[08:22:33] 200 Type set to ASCII.
[08:22:33] PROT P
[08:22:33] 200 PRIVATE data channel protection level set
[08:22:33] PASV
[08:22:33] 227 Entering Passive Mode (10,1,1,20,5,231).
[08:22:34] Opening data connection to 10.1.1.20 Port: 1511
[08:22:34] LIST
  • 11952 posts
Posted 12 July 2006 - 07:50 PM
1. Send the complete log from SmartFTP
2. Send the log form the other FTP client where the LIST works.
#5 jlcfly
jlcfly
  • 3 posts
Posted 14 July 2006 - 08:01 PM
SmartFTP's log
[12:56:01] SmartFTP v2.0.996.40
[12:56:01] Resolving host name "12.42.46.196"
[12:56:01] Connecting to 12.42.46.196 Port: 21
[12:56:01] Connected to 12.42.46.196.
[12:56:01] 220 hshhp-ts1 X2 WS_FTP Server 5.0.4 (305233259)
[12:56:01] AUTH TLS
[12:56:02] 234 SSL enabled and waiting for negotiation
[12:56:02] Connected. Exchanging encryption keys...
[12:56:02] Session Cipher: 128 bit RC4
[12:56:03] TLS encrypted session established.
[12:56:03] PBSZ 0
[12:56:03] 200 PBSZ=0
[12:56:03] USER freeclear
[12:56:03] 331 Password required
[12:56:03] PASS (hidden)
[12:56:03] 230 user logged in
[12:56:03] SYST
[12:56:03] 215 UNIX
[12:56:03] TYPE I
[12:56:03] 200 Type set to IMAGE.
[12:56:03] REST 0
[12:56:03] 350 setting restart marker to 0
[12:56:03] PWD
[12:56:03] 257 "/freeclear" is current directory
[12:56:03] TYPE A
[12:56:04] 200 Type set to ASCII.
[12:56:04] PROT P
[12:56:04] 200 PRIVATE data channel protection level set
[12:56:04] PASV
[12:56:04] 227 Entering Passive Mode (10,1,1,20,6,40).
[12:56:04] Opening data connection to 10.1.1.20 Port: 1576
[12:56:04] LIST
[12:56:25] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
[12:57:05] Timeout (40s).
[12:57:05] Active Help: http://www.smartftp....kb/index.php/74
[12:57:05] Client closed the connection.
Core FTP's log
Welcome to Core FTP, release ver 1.3c, build 1447.5 (U) --
  • 11952 posts
Posted 14 July 2006 - 08:29 PM
Hmm. Interesting. Is there a chance we can get a test account on the FTP server in question?
