Connect() function of SmartFTP did not return a value to Navision-Attain
3 replies to this topic
#1 BTC
BTC
    Brussels - Belgium
Posted 04 April 2006 - 11:09 AM
Hello,
We use SmartFTP library STA class in the development environment of Navision Attain (ERP) with ProFTPd server. When a FTP error occurs during login, the process using smart FTP is locked. It seems that the Connect() function of SmartFTP didn't return a value to our application in this case. This error occurs at every login error.
The SmartFTP trace :
[20060328 13:52:07] SmartFTP FTP Library v1.5.6.0
[20060328 13:52:07] Resolving host name "FTPservername"
[20060328 13:52:07] Connecting to 62.72.105.222 Port: 21
[20060328 13:52:07] Connected to FTPservername.
[20060328 13:52:07] Server closed connection
We have used the connection procedure in a loop with a dialog to reproduce and understand more easily the problem. The process only connects and disconnects from the FTP server.
Global function :
gdialog.OPEN();
UpdateDialog(1,BTC014);
IF (gf_LoadFTPSetup) THEN
BEGIN
  WHILE i<1000 DO
  BEGIN
	gboo_RetValue:=TRUE;
	CLEAR(FTPC);
	IF gf_Connect THEN
	BEGIN
	END
	ELSE gboo_RetValue:=FALSE;
	i:=i+1;
	SLEEP(100);
	IF NOT(gboo_RetValue) THEN
	  lf_SaveFTPTrace()
	ELSE
	BEGIN
	  IF NOT(lf_DeleteFile(gcu_FolderMgt.gf_RetLocWork(),gtex50_FTPTraceFileName)) THEN
		lcu_EventLog.gf_InsertEventCode(2,4,0,'FTP','E-28-020','','','','','','','','','','',FALSE);
	END
  END
END;
CloseDialog;
gf_Connect() retboo : Boolean
IF NOT(SmartFTPKey()) THEN
BEGIN
  lcu_EventLog.gf_InsertEventCode(3,3,0,'FTP','E-28-043','','','','','','','','','','',FALSE);
  EXIT(FALSE);
END;
UpdateDialog(1,BTC006);
CREATE(FTPC);
FTPC.Host:=grec_NWDSetup."FTP Server";
FTPC.Username:=grec_NWDSetup."FTP Login";
FTPC.Password:=grec_NWDSetup."FTP Password";
FTPC.Protocol:=0;//normal (not SSL)
FTPC.Passive:=grec_NWDSetup."FTP Passive Mode";
FTPC.DataTransferType:=2; //binary
FTPC.HidePassword(TRUE);
FTPC.LogFile:= gcu_Conv.MakeFilePath(gcu_FolderMgt.gf_RetLocWork(),gtex50_FTPTraceFileName);
IF FTPC.Connect()<>0 THEN
BEGIN
  lcu_EventLog.gf_InsertEventCode(3,3,0,'FTP','E-28-005','','','','','',FORMAT(FTPC.LastError()),'','','','',FALSE);
  EXIT(FALSE)
END;
IF NOT(gf_CheckStatus) THEN
   EXIT(FALSE);
UpdateDialog(1,BTC017);  //2005 09 07 - ED - NWD1.RC03;
gf_Disconnect();
EXIT(TRUE);
gf_Disconnect() Retboo : Boolean
UpdateDialog(1,BTC007);
IF (FTPC.Close()<>0) THEN
BEGIN
  lcu_EventLog.gf_InsertEventCode(3,3,0,'FTP','E-28-006','','','','','',FORMAT(FTPC.LastError()),'','','','',FALSE);
  CLEAR(FTPC);
  EXIT(FALSE)
END;
CLEAR(FTPC);
UpdateDialog(1,BTC018);
EXIT(TRUE);
It's a critical issue because:
Our application must download and upload files at every period of time.
We can not see that the process is not responding in a short interval.
This problem locks the application: the users have to kill the task.
That often arrives because we work in a country with low internet bandwidth rate.
When removing the events on the SmartFTP automation (FTPC WithEvent=No), the problem do not seem to occur: the application is not blocked when the server closes the connection during login. This is not an acceptable solution for us. We use SmartFTP to handle event: we made a progress bar with transfer events.
Why the connect() function of SmartFTP library didn
  • 11975 posts
Posted 04 April 2006 - 05:53 PM
Please try again with the latest version of the FTP Library:
http://www.smartftp....tplib/download/
#3 BTC
BTC
    Brussels - Belgium
Posted 14 April 2006 - 06:01 PM
Hello,
We have the same problem with the new version.
It happens here on another FTP server:
[20060411 09:46:18] SmartFTP FTP Library v1.5.8.3
[20060411 09:46:18] Resolving host name "ftpservername"
[20060411 09:46:18] Connecting to 200.150.140.150 Port: 21
[20060411 09:46:41] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
[20060411 09:46:41] Client closed the connection.
As reported above when an error occurs at this connection step, the connect() function of the library didn
  • 11975 posts
Posted 14 April 2006 - 06:47 PM
Did you try to disable (or not handle) all the events from the FTP Library? Cause this may cause a dead lock.
