TimeOut Problem
3 replies to this topic
#1 ckstech
ckstech
Posted 17 March 2006 - 11:21 PM
I am trying to upload to an ftp server using AUTH TLS. I am getting a timeout error when request a listing or try to upload a file. Here is the log:
[20060317 22:47:08] 220-FTPSECRE IBM FTP CS V1R4 at MVSSY2.TEALE.CA.GOV, 22:46:19 on 2006-03-17.
[20060317 22:47:08] 220 Connection will not timeout.
[20060317 22:47:08] AUTH TLS
[20060317 22:47:09] 234 Security environment established - ready for negotiation
[20060317 22:47:09] Connected. Exchanging encryption keys...
[20060317 22:47:09] Session Cipher: 128 bit RC4
[20060317 22:47:09] TLS encrypted session established.
[20060317 22:47:09] PBSZ 0
[20060317 22:47:09] 200 Protection buffer size accepted
[20060317 22:47:09] USER xxxxxxxx
[20060317 22:47:09] 331 Send password please.
[20060317 22:47:09] PASS xxxxxxxx
[20060317 22:47:10] 230 HDTWIXP3 is logged on. Working directory is "HDTWIXP3.".
[20060317 22:47:10] SYST
[20060317 22:47:10] 215 MVS is the operating system of this server. FTP Server is running on z/OS.
[20060317 22:47:10] FEAT
[20060317 22:47:10] 211- Extensions supported
[20060317 22:47:10] SIZE
[20060317 22:47:10] AUTH TLS
[20060317 22:47:10] PBSZ
[20060317 22:47:10] PROT
[20060317 22:47:10] 211 End
[20060317 22:47:10] TYPE I
[20060317 22:47:10] 200 Representation type is Image
[20060317 22:47:10] REST 0
[20060317 22:47:10] 504 Restart not allowed with active security mechanism
[20060317 22:47:10] PWD
[20060317 22:47:10] 257 "'HDTWIXP3.'" is working directory.
[20060317 22:47:10] SITE LRECL=11 BLOCKSIZE=4400 RECFM=FB
[20060317 22:47:10] 200 SITE command was accepted
[20060317 22:47:10] CWD 'HD.WIX8140.HDVWIXP.'
[20060317 22:47:10] 250 "HD.WIX8140.HDVWIXP." is the working directory name prefix.
[20060317 22:47:10] 257 "'HD.WIX8140.HDVWIXP.'" is working directory.
[20060317 22:47:12] FEAT
[20060317 22:47:12] 211- Extensions supported
[20060317 22:47:13] SIZE
[20060317 22:47:13] AUTH TLS
[20060317 22:47:13] PBSZ
[20060317 22:47:13] PROT
[20060317 22:47:13] 211 End
[20060317 22:47:13] TYPE A
[20060317 22:47:13] 200 Representation type is Ascii NonPrint
[20060317 22:47:13] PROT P
[20060317 22:47:13] 200 Data connection protection set to private
[20060317 22:47:13] PASV
[20060317 22:47:13] 227 Entering Passive Mode (134,187,32,2,196,56)
[20060317 22:47:13] LIST
[20060317 22:47:43] Timeout (30s).
[20060317 22:47:43] 3
[20060317 22:47:43] Client closed the connection.
Can anybody help me?
  • 11953 posts
Posted 18 March 2006 - 01:08 AM
Set the Passive property to false/VARIANT_FALSE and try again. Always test with the SmartFTP Client and with other FTP clients if you have the same problem.
#3 ckstech
ckstech
Posted 18 March 2006 - 01:39 AM
I made that change in my vb code to:
objFTP.Passive = False
Now it gets past the list command, but my upload is failing:
Dim nRestartLo: nRestartLo = 0
Dim nRestartHi: nRestartHi = 0
Dim vDataPath As String
Dim strMsg
objFTP.UploadFile(LocalFile, filetosend, nRestartLo, nRestartHi)
Here is the log:
227 Entering Passive Mode (134,187,32,2,196,118)
[20060318 01:34:41] LIST -T
[20060318 01:34:41] 550 No data sets found.
[20060318 01:34:41] TYPE A
[20060318 01:34:41] 200 Representation type is Ascii NonPrint
[20060318 01:34:41] PASV
[20060318 01:34:41] 227 Entering Passive Mode (134,187,32,2,196,118)
[20060318 01:34:41] PROT P
[20060318 01:34:41] 200 Data connection protection set to private
[20060318 01:34:41] PORT 192,77,14,40,6,202
[20060318 01:34:41] 200 Port request OK.
[20060318 01:34:41] STOR D060317.T173435.R123456
[20060318 01:34:51] Timeout (30s).
[20060318 01:34:51] 3
[20060318 01:34:51] Client closed the connection.
I have tested it with SmartFTP Client 2.0 and everything works just fine.
Do you have any other ideas?
  • 11953 posts
Posted 18 March 2006 - 03:22 AM
Can you post the log from SmartFTP? Then we can compare the differences and see what settings have to be changed.
