PortIP setting
#1 2BrightSparks
2BrightSparks
  • 44 posts
Posted 24 February 2006 - 10:31 AM
Hi, we're converting from Indy 10 to this component. In Indy 10 they had a property called ExternalIP. The help file on it says:
Specifies the IP address used when the client sends the FTP PORT or EPRT commands behind a NAT-based firewall.
You could then specify the range of ports to use. Is this the same as the PortIP property in Smart FTP? If not, can you tell me which one is? Thanks
  • 11954 posts
Posted 24 February 2006 - 02:10 PM
I don't know Indy 10 but from what information you posted the PortIP propery in the SmartFTP FTP Library seems to be the same as the ExternalIP property in Indy 10. You need to set the PortMode property to PortModeManual before the IP in the PortIP property is used.
To limit the ports used for a PORT/EPRT command please see the IFTPPortPool Interface. You can set the range with the SetPortRange method.
