Connection problems via proxy (Webwasher)
5 replies to this topic
#1 bluemoon
bluemoon
  • 6 posts
Posted 27 January 2006 - 10:28 AM
I posted the following question already in the german forum, now I hope someopne can hep me here:
Up to version 1.1.985 we were able to use SmartFTP with our Proxy (Webwasher):
SmartFTP v1.1.985.6
Resolving host name 172.20.8.63...
Resolving host name ftp.nai.com...
Connecting to Proxy (172.20.8.63) -> IP: 172.20.8.63 PORT: 21
Connected to Proxy (172.20.8.63) -> Time = 0ms
220 Webwasher FTP Proxy 5.3.0 build 1953
USER DOMAIN\USER
331 User name okay, need password.
PASS (hidden)
230-Webwasher Authentication successful.
230 Use SITE command or another USER/PASS sequence.
USER anonymous@ftp.nai.com
PASS (hidden)
230-You are connected to ftp.nai.com.Your use is subject to the terms and
230-conditions in Legal.TXT and Usage.TXT files
230 Anonymous user logged in.
Since then (and also the V2) SmartFTP does not connect to any remote server (same settings in preferences!):
SmartFTP v2.0.993.13
Resolving host name "172.20.8.63"
Connecting to 172.20.8.63 Port: 21
Connected to ftp.nai.com.
530 Gateway authentication needed. Syntax: LocalUser@RemoteUser@Host
Cannot login waiting to retry (30s)...
Where is my mistake? What's the problem?
  • 11974 posts
Posted 27 January 2006 - 12:23 PM
Check your favorite item proxy settings.
#3 bluemoon
bluemoon
  • 6 posts
Posted 27 January 2006 - 01:29 PM
Thanks for your reply. But I made a fresh install. Also with a completely fresh windows installation we receive same behaviour :unsure:
  • 11974 posts
Posted 27 January 2006 - 01:41 PM
If possible please post a screenshot of the Settings->Connection->Proxy dialog.
#5 bluemoon
bluemoon
  • 6 posts
Posted 27 January 2006 - 01:59 PM
Here you go:
Posted Image
The user is typed like DOMAIN\USER.
I made a TCP Trace and the very first commando I see is "USER user@remotehost". It seems SmartFTP ignores the checkbox "login to firewall/proxy".
#6 bluemoon
bluemoon
  • 6 posts
Posted 27 January 2006 - 03:30 PM
It was a simple bug in SmartFTP.
Thanks for the fast troubleshooting.
