FTP hangs when releasing interface
9 replies to this topic
#1 pro510
pro510
  • 33 posts
Posted 15 December 2005 - 03:41 PM
Every now and then when I call the Release function on the library it hangs and does not return. The ftp log does not give any hint:
[20051215 15:25:06] SmartFTP FTP Library v1.5.7.5
[20051215 15:25:06] Resolving host name "169.254.109.212"
[20051215 15:25:06] Connecting to 169.254.109.212 Port: 21
[20051215 15:25:06] Connected to 169.254.109.212.
[20051215 15:25:06] 220 Service ready for new user.
[20051215 15:25:06] USER bssaudio
[20051215 15:25:06] 331 User name okay, need password.
[20051215 15:25:06] PASS trousers
[20051215 15:25:07] 230 User logged in, proceed.
[20051215 15:25:07] SYST
[20051215 15:25:07] 215 BSS system type.
[20051215 15:25:07] FEAT
[20051215 15:25:07] 500 Syntax error, command unrecognized.
[20051215 15:25:07] TYPE I
[20051215 15:25:07] 200 Command okay.
[20051215 15:25:07] REST 0
[20051215 15:25:07] 550 Requested action not taken.
[20051215 15:25:07] PWD
[20051215 15:25:07] 257 "/" is Current Directory
[20051215 15:25:07] PORT 169,254,59,100,166,109
[20051215 15:25:07] RETR dfp.dfh
[20051215 15:25:07] 150 File status okay; about to open data connection.
[20051215 15:25:07] 89 bytes transferred. (1.37 KB/s) (63 ms)
[20051215 15:25:07] 226 Closing data connection.
[20051215 15:25:07] PORT 169,254,59,100,166,111
[20051215 15:25:07] RETR 00000000.dfp
[20051215 15:25:07] 64564 bytes transferred. (212 KB/s) (297 ms)
[20051215 15:25:07] QUIT
[20051215 15:25:07] 221 Service closing control connection.
[20051215 15:25:07] Client closed the connection.
My initialisation and destruction code is as follows:
CFTPClient::CFTPClient ()
	m_bInitialised = FALSE;
	// init COM for this thread
	::CoInitialize(NULL);
	try
		sfFTPLib::IGlobalPtr pGlobal;
		if(SUCCEEDED(pGlobal.CreateInstance(__uuidof(sfFTPLib::Global))))
			// Load the licence file into the DLL
			if (pGlobal->LoadLicenseKeyData(_szLicence))
				HRESULT hr = m_ftp.CreateInstance(__uuidof(sfFTPLib::FTPConnectionMTA));
				if (SUCCEEDED(hr))
					m_bInitialised = TRUE;
					if (nGetRegistryInt (REG_SECTION_GENERAL, _T("LogFTP"), FALSE, FALSE))
						// Use log file
						m_ftp->LogFile = _T("C:\\FTPLOG.TXT");
					// Set timeout
					m_ftp->Timeout = nGetRegistryInt (REG_SECTION_GENERAL, _T("FTPTimeout"), 30, FALSE);// 30 second timeout
			else
				AfxMessageBox(_T("Failed to load FTP license key data."), MB_ICONERROR);
	catch (_com_error& ce)
		dump_com_error (ce);
	ASSERT (m_bInitialised);
CFTPClient::~CFTPClient ()
	if (m_ftp)
		// Release ftp client
		m_ftp.Release (); // This is the function call which hange
	::CoUninitialize ();
Here is the stack if that is any use
 	ntdll.dll!7c90eb94()
 	ntdll.dll!7c90e9ab()
 	kernel32.dll!7c8094f2()
 	user32.dll!77d48832()
 	user32.dll!77d487ff()
 	kernel32.dll!7c8399f3()
 	user32.dll!77d4bbfe()
 	user32.dll!77d49278()
 	user32.dll!77d4bcad()
 	sfFTPLib.dll!11978724()
 	sfFTPLib.dll!11978a15()
 	sfFTPLib.dll!11946b3f()
 	sfFTPLib.dll!119537f8()
 	sfFTPLib.dll!11953858()
 	sfFTPLib.dll!1195370e()
 	Roadrunner.exe!_com_ptr_t<_com_IIID<sfFTPLib::IFTPConnection,&_GUID_65d75061_6343_4124_9d64_64f1eabb34c2> >::Release()  Line 582 + 0x12	C++
>	Roadrunner.exe!CFTPClient::~CFTPClient()  Line 136	C++
Any ideas on why this is happening?
  • 11952 posts
Posted 16 December 2005 - 07:09 PM
Hi ..
It looks like a multi thread problem.
Try to use ::CoInitializeEx(0, COINIT_MULTITHREADED) instead of ::CoInitialize().
Do you use the library in Async mode or not?
Do you register to any events? If yes, did you revoke it before calling the Release function?
Is the deconstructor called from another thread while another method of the IFTPConnectionMTA interface is in progress?
#3 pro510
pro510
  • 33 posts
Posted 19 December 2005 - 11:38 AM
The problem can occur in the startup of our application and is therefore not using multiple threads at that time.
We cannot use this in our main thread as we need OLE. We use AfxOleInit which initialises COM in single threaded model. I have removed the COM init from our ftp constructor now.
We do not use async mode.
No we do not register to any events
No.
Graham
#4 pro510
pro510
  • 33 posts
Posted 19 December 2005 - 03:22 PM
I have also noticed that when it is stuck in this call, my main application has a message loop running. Could it be something to do with the "UseMessageLoop" member in the FTP connection class? I have tried forcing that to FALSE.
It may also be worth mentioning, that I do see a thread exit in my trace output when I call Release.
Graham
#5 mb
  • 11952 posts
Posted 19 December 2005 - 07:02 PM
Try to call Abort() and then Close() which is not documented before you call Release.
In our code it would look like this:
if (m_pFTP)
m_pFTP->Abort();
m_pFTP->Close();
// also sets the interface pointer to NULL
m_pFTP.Release();
if (m_pDispEvent)
m_pDispEvent->Revoke();
m_pDispEvent->Release();
m_pDispEvent = NULL;
bRet = true;
#6 pro510
pro510
  • 33 posts
Posted 20 December 2005 - 09:22 AM
Still hangs in the Release function.
#7 mb
  • 11952 posts
Posted 20 December 2005 - 12:00 PM
Do you have the problem in the Release and Debug build?
#8 pro510
pro510
  • 33 posts
Posted 20 December 2005 - 01:18 PM
It happens in both release and debug. It seems to happen more frequently in debug however, which would suggest a timing issue.
#9 mb
  • 11952 posts
Posted 26 December 2005 - 06:56 AM
I do not have any other ideas at the moment. But if you want I can provide you a debug build of the library including the PDB files. If you are interested please send an email to any of our email addresses and request it.
#10 pro510
pro510
  • 33 posts
Posted 06 January 2006 - 10:23 AM
I have sent an e-mail to your sales e-mail address. I tried to PM you but it said your inbox was full.
