SmartFTP Forums: established connection was aborted by the software... - SmartFTP Forums
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   alanevil
  • Group: Members
Posted 23 July 2005 - 08:16 PM
When I try to connect to my site I get the following error:
An established connection was aborted by the software in your host machine.
What does this mean and how do I correct it? I've been using the older versions of this program for years and never seen this.
#2 User is offline   McOwnage
  • Group: Members
Posted 26 July 2005 - 05:59 AM
The Knowledge Base is useful here
found this here http://www.smartftp....kb/index.php/74
An established connection was aborted by the software in your host machine. Software caused connection abort
This error can occur when the local network system aborts a connection, such as when WinSock closes an established connection after data retransmission fails (receiver never acknowledges data sent on a datastream socket). Possibly due to a data transmission timeout or protocol error.
Tip: You can try setting the Server Timeout higher, which might help in some cases.
Best to check http://www.smartftp.com/support/kb/ before posting if you get the problem after you check there then post that you already did what was suggested in the Knowledge Base.
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
