SmartFTP Forums: Connection Problems - SmartFTP Forums
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Connection Problems
#1 User is offline   DavidJaymz
  • Group: Members
    London (UK)
  • Interests:
    Space, Corvettes Music (Trading live concerts) Web
Posted 29 July 2005 - 08:57 AM
I've been using smartFTP for years but have now got a strange problem.
I use smartFTP to connect to two domains from two locations. Both domains are on the same host but different servers. At work i can connect to both domains, while at home i can connect to only one.
When trying to get onto the second account I get the below connection progress.
    SmartFTP v1.5.988.49
    Resolving host name "ftp03.powweb.com"
    Connecting to 66.152.97.20 Port: 21
    Connected to ftp03.powweb.com.
220---------- Welcome to Pure-FTPd [TLS] ----------
220-You are user number 26 of 268 allowed.
220-Local time is now 01:40. Server port: 21.
220-This is a private system - No anonymous login
220 You will be disconnected after 15 minutes of inactivity.
    USER user
331 User user OK. Password required
    PASS (hidden)
230-User djwebb has group access to:  customer
230 OK. Current restricted directory is /
    SYST
215 UNIX Type: L8
    FEAT
211-Extensions supported:
 EPRT
 IDLE
 MDTM
 SIZE
 REST STREAM
 MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
 MLSD
 ESTP
 PASV
 EPSV
 SPSV
 ESTA
 AUTH TLS
 PBSZ
 PROT
211 End.
    Detected Server Software: PureFTPd
    PWD
257 "/" is your current location
    TYPE I
200 TYPE is now 8-bit binary
    PORT 192,168,1,100,10,253
200 PORT command successful
    MLSD
    Timeout (20s).
    Active Help: http://www.smartftp.com/support/kb/index.php/45
    Client closed the connection.
    Automatic failover of data connection mode from "Active Mode (PORT)" to "Passive Mode (PASV)".
It stops at the same point everytime, I've tried in PORT and PASV modes its always the same and my other domain will connect in either PORT or PASV.
Does anyone know anything about this problem? its getting very frustrating and could cause me to leave my favourite ftp software for one that allows me to connect to both domains.
#2 User is offline   DavidJaymz
  • Group: Members
    London (UK)
  • Interests:
Posted 29 July 2005 - 10:05 AM
I just went through the login again and followed both servers at they tried.... it looked like server one was in PASV while server two was in PORT mode although the connection setting was PASV.
I dug a little deeper and found that somehow my server two "bookmark" had been set to connect in PORT. I've changed it to PASV and can now connect... Woohoo
This has been bugging me for days... I need to learn to trouble shoot better. :-)
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
