Not Receiving "On Transfer Queue Item Group Proccessd" Email Notification
#1
Posted 02 November 2009 - 09:44 PM
I've checked "On transfer queue item group processed" and tested our email settings (other notification options work great) but for some reason if I drop three items into the monitored folder I get emails for each one, not just one for the entire group.
Is this how the notifications are suppose to work? If so that's fine, I'm wondering if it would it make more sense to have the monitor folder launch an email script "OnEnd", although I'm not sure "OnEnd" refers to an individual file uploading in the queue, or the entire queue being completed.
Any suggestions to accomplish this will result in us immediately purchasing this outstanding product!
- Upon a group of files being uploaded (via the folder monitor) send an email saying that the group has processed.
~ Jon
#2
Posted 02 November 2009 - 10:29 PM
What version are you running?
-> Please post the system information from the menu: Help->About "System Information" dialog.
#3
Posted 03 November 2009 - 05:19 AM
+- System ----------------------------- Microsoft Windows 2008 R2 Server Enterprise Edition (full installation) (Build 7600) CPU Speed : 1861 MHz Total Memory : 12287 MB Free Memory : 10838 MB +- SmartFTP --------------------------- Version : 4.0.1063.0 Time Stamp : 2009-10-31 20:55:55 Platform : x64 Unlicensed Days in use : 0 +- Language --------------------------- en-US +- Internet Explorer ------------------ Version : 8.0.7600.16385 +- Winsock ---------------------------- Winsock : 2.2
Since posting this I've got a vbs script enabled via the tab under the transfer queue monitor. It does work except it send out an alert at the beginning of the transfer rather than when all the items have finished:
Dim objMessage
Set objMessage = CreateObject("CDO.Message")
objMessage.Subject = "The Items in Your Locally Monitored Folder Finished Transferring Successfully"
objMessage.From = "you@you.com"
objMessage.To = "me@me.com"
objMessage.TextBody = "A bunch of items in this particular transfer queue monitored folder finished transferring. Enjoy!"
Sub TransferQueueOperation_OnEnd()
'==This section provides the configuration information for the remote SMTP server.
'==Normally you will only change the server name or IP.
objMessage.Configuration.Fields.Item _
("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
'Name or IP of Remote SMTP Server
("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "smtp.somewhere.com"
'Server port (typically 25)
("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
objMessage.Configuration.Fields.Update
'==End remote SMTP server configuration section==
objMessage.Send
End SubThanks for any help!
#4
Posted 03 November 2009 - 06:17 AM
Copy Operation (not what you want)
- The operation of the item starts
The operation creates the new children (there is parent/child relation) and groupid of the item is inherited
The operation adds the new items to the queue
The operation ends (the Operation_OnEnd event handler is called here)
The item status is to "Wait For Children".
Once all children are processed the parent item status is set to finished. When this happens the queue checks whether there are any more items with the groupid. Since this is the last item the "On Queue Item Group" event is fired.
Monitor Operation
- "Item" detects changes in the monitored folder
The operation creates the new children (there is parent/child relation) and the groupid of the item is inherited
The operation ends (the Operation_onend event handler is called here)
The item status is immediately reset (set to idle). Meaning it does not wait until the new children are finished.
The monitor item does not wait for its children because this way it can add new items to the queue as soon as it detects a change.
As you can see at the time the status is set to idle there is most likely another item with the same groupid in the queue and therefore the "On Queue Item Group" event is not fired.
Possible ways to fix this:
1. For monitor operations use a new groupid for all the items the operation adds.
2. Make the monitor operation wait until all children are finished
I want to see how I can implement number one. I'm not yet convinced that waiting for the monitor operation is a good idea, but it actually might be. Any thoughts on this?
#5
Posted 04 November 2009 - 12:54 AM
Monitor Operation
Hey Mat,
Thanks for the great feedback. I only see these options for transfer queue operations: Unknown, Copy, Move, Delete, Edit, ReadDirectory, SetPermissions, Custom how would I get it to Monitor and still copy?
~ Jon
#6
Posted 04 November 2009 - 02:11 AM
So set the operation to copy and then enable the monitor in the Monitor dialog in the transfer queue item properties.
#7
Posted 04 November 2009 - 11:16 PM
Hey Mat,
I'm really feeling lost with all the SDK info I've been reading and would like to simply be pointed in the right direction to get this accomplished. I've read up on the "ScriptHost" and "TransferQueueOption" and neither seem to offer what I need, which seems like a small request:
1. If one of the three transfer queues I have adds files via the monitoring, send an email simply stating files have been added to this queue.
2. If one of the three transfer queues finishes transferring X amount of files, send an email simply stating files in that particular queue have finished transferring.
Is there any doc or sample VBS code you could point me to that I can use? At times we have up to 200 files transferring per queue so an email for each would be too much. Just two: one for the beginning and end of the queue would be awesome.
~ Jon
#8
Posted 04 November 2009 - 11:45 PM
Then enable the "Item Group" notification.
#9
Posted 05 November 2009 - 12:01 AM
Thanks Mat, I believe this is on the patched version you provided me?
Something odd I'm experiencing with this version though, if I try to upload something to a server (that works perfectly fine with other FTP clients) the transfer fails and I keep getting the following:
[15:58:27] MLST test.zip
[15:58:27] 550 File or directory not found.
[15:58:27] The operation has been added to the Transfer Queue. Check the Transfer Queue for the status.
I've tried multiple servers and not getting anywhere, any ideas?
~ Jon
This post has been edited by Jon H: 05 November 2009 - 12:02 AM
#10
Posted 05 November 2009 - 01:32 AM
Correct
>Upload
This is no error per se. SmartFTP uses multiple connections:
- One connection for the browser
- One or more connections for the transfers
To check whether your transfers complete check the transfer queue. What you see in the log in the remote browser (e.g. the 550 file not found) is irrelevant for the transfers.
Help
